06-20-2006, 08:40 | #4 (permalink) | |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | Hello Quote:
I DID CHECK. EVEN CHANGED THE HDD FROM A WORKING PHONE, BUT STILL THE SAME. HAVE A NICE DAY. | |
06-20-2006, 09:05 | #5 (permalink) | |
Banned Join Date: Nov 2005
Member: 204243 Status: Offline Thanks Meter: 67 | Quote:
08-17-2006, 20:34 | #8 (permalink) |
Insane Poster Join Date: Mar 2003 Location: Poland Age: 44
Member: 24741 Status: Offline Thanks Meter: 7 | hi i had the same problem try to format your hdd by JAF - format file system , and put on battery cover otherwise phone say that "hard Drive Not Available" form me works fine |
02-09-2008, 11:04 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | here is the solution(we do not have to use any of box or sofeware): 1. normally i will turn on the phone and press *#7370# to restore to factory setting first. 2. TAKE OFF BACK COVER. reboot phone by holding the (pen-key), the phone will boot as safemode. (it looks no different from normal mode) 3. go to setting--> harddisk (now you will still see "harddisk is not available") 4. PUT BACK COVER ON (do this slowly). then the phone will work very slow BUT THE PHONE IS NOT HANG. 5. you have to be patient, and press option key, and wait for phone responds, it normally takes from 2mins to 5 mins (some phones responds fast, some phones responds slower, depands how it reads harddisk) 6. after option menu comes up, choose harddisk to format (formatting takes about 15 mins or more, be patient, wait until it finish, after formatting harddisk, every thing will work ok again) note: after put your backcover back, each key you press, phone will respond very slow, because it's reading harddisk, but THE PHONE IS NOT HANG Dear members, more Device hangs when booting Cause: - Corrupt HDD - Defective HDD - Defective device - HDD sticking Cannot access the HDD Cause: - Battery cover not in place - Magnet missing from battery cover - Damaged HDD - Corrupt data on HDD - Poor interconnect between HDD and PWB HDD Corrupt Cause: - Data installed from factory, that was corrupted - Applications installed on the HDD by user, not compatible S60 applications that are not version 3.0 (previous versions) are not compatible with N91. - Application install process to the HDD by user, that are not compatible If an application was copied from another device to a PC and then onto the HDD via mass storage, this will corrupt the HDD. Applications that worked in non-S60 3.0 devices will not work in the N91 or other S60 3.0 devices because of binary incompatability. Example: an application that works in a N70 or 6630 will not work in the N91 or N71. If an application was downloaded from the MMC of these devices and transferred (drag and Drop) into the N91, this would corrupt the HDD and the HDD would have to be formatted to function again. The N91, on startup, will see applications that were copied from the PC to the HDD. It will try to install these applications; this will lock the HDD and not allow access. This problem, with early sw (version 1.0), was only able to be repaired by formatting the HDD with Phoenix, because the USB connection could not access the HDD. Also, if the customer took a backup of a corrupted HDD image, when they restore this image to the device it will have the same fault. If an application was interrupted when it was being installed on the HDD by a power cycle. Applications have to be allowed to install uninterrupted Slow Accessing Applications Causes: SMS, MMS, Themes, and some applications if they are loaded onto the HDD, will cause slow access times. All these items should be loaded onto the devices internal memory and not the HDD. Quick Test tips If the device will not boot: - Restart the device with the battery cover removed If the device boots then there is a HDD issue. If the device boots but can not see the HDD - Make sure the battery cover is in place. - Check that there is a magnet in the B-Cover Use a metal object (a paper clip works) and see if it sticks to the lower right side of the device (opposite to the USB connector) If it does not stick replace the b-cover with a good b-cover. Retest. Testing There are different tools available to test and repair the HDD. They are available from the User Interface (UI), through the “Mass Storage” USB selection when connected to a PC and through Phoenix test software. Depending on the level of corruption on the device, this will limit which tools can be used. If the HDD is not accessible through the UI or the PC, then the last chance to format the HDD is through Phoenix |
N91 Problem to Detecting.... | Gsm Lab | MT-BOX | 38 | 07-31-2007 08:52 |
N91 problem | beega | Nokia Base Band 5 ( BB-5 ) | 0 | 12-12-2006 08:50 |
Route 66 on N91 Problems | alpinanady | Nokia Multimedia | 3 | 08-30-2006 18:07 |
N91 problems........... | tostefo | MT-BOX | 3 | 06-30-2006 00:49 |
