04-17-2007, 06:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | n91 when put in charge battery geting hot thanks. |
04-18-2007, 05:19 | #4 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | hi guys thanks for reply.can you tell me where is loceted the power amlifire? battery connector is ok. i dont thing so its pa problem u thing so? and which capiciter do i have to check because to many capiciter? thanks again for ur help. |
04-24-2007, 00:15 | #11 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | yes i agree. i tryed to heated but stil same. i take out all capisiter and ressiter near retu IC but stil show shoting.i really dont now what to if i take it out IC phone will go dead.and i dont want to kil phone. |
04-24-2007, 06:30 | #12 (permalink) |
No Life Poster Join Date: Aug 2005 Location: SILIGURI Age: 46
Member: 170589 Status: Offline Thanks Meter: 1,848 | check out the shorting ohms between the positive and negative battery connector, check out without on the set, if there would be simple lekage shorting between to polarity it may your pa damage. |
05-01-2007, 05:14 | #13 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | thanks for reply, but i alredy treyd pa but stil same.i took out battery conncetion as well but stil same i dont have much knolage about miter so i dont how can i check capiceter. |
05-02-2007, 08:28 | #15 (permalink) | |
Major Poster Join Date: Aug 2005 Age: 42
Member: 173215 Status: Offline Thanks Meter: 3 | Quote:
L7 white screen only when put in bootmode repair done | hanif007 | Smart-Clip | 1 | 04-21-2008 07:48 |
n73 hot when put in batt!!!! | danielliew | Nokia Hardware & Hardware Repair | 3 | 12-05-2007 13:55 |
V3i Bootloader Screen When Put In Battery | wirelessrush | Motorola Hardware Repair | 14 | 11-21-2007 05:14 |
E1000 switches off when put on charging | someone2408 | Motorola P2k | 3 | 04-30-2006 20:26 |
V220 dead - but screen lights when putting in charger without battery | James_S | Motorola P2k | 3 | 10-29-2005 20:44 |
