Old 05-20-2003, 16:31   #1 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
N9210i PDA is working GSM PHONE SECTION IS DEAD.
I need help to repair NOKIA 9210i communicator.
Its PDA section is working OK... but GSM PHONE SECTION IS TOTALY DEAD.. and don't power on..
I flashed it (MCU + PPM) but problem is the same anyone here can guide me how I can repair it..
Best Regards,
Wahab
Old 05-22-2003, 13:32   #2 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
Still waiting for reply...
I checked that ONLY BOARD which have CCONT/COBBA is fualty.. Becuase I changes it with working 9210 than problem was the same.
Please tell me where maybe the problem.
Best Regards,
Wahab
Old 05-24-2003, 10:13   #3 (permalink)
GSMWolf's Avatar
Member: 4454
is power switch OK?
PDA is switching automatically when you give battery inside, but phone section you must switch by pressing button. maybe this button is faulty. check keyboard...
Wolf.
Old 05-24-2003, 11:06   #4 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
POWER SWTICH IS OK..
The problem in lower PCB
Best Regards,
Wahab
Old 05-24-2003, 16:44   #5 (permalink)
GSMWolf's Avatar
Member: 4454
did you tried to flash phone? are you sure that this is HW problem?
....but what else this should be than HW....
I never heard about this. PDA working, phone not.... :-(
...read service manual level3...maybe there is solution....
Wolf.
Old 05-28-2003, 03:20   #6 (permalink)
Member: 129
hi,
Change the flex.
The problem with the 9210 is that the flex comes as keyboard unit and flex as one.(i mean the flex below the flex cover)
I had this fault a couple of times ,phone dead pda working.
good luck.
Old 05-28-2003, 04:36   #7 (permalink)
Member: 11889
Compare
Hi,
try put the bad 9210i main board to another 9210 or 9210i for testing the function. Then u will find out which part has problem.
Hopr this can help you for faster troble shooting.
Old 05-28-2003, 06:43   #8 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
I already put Lower PCB to the other 9210.. same problem..
its main lower PCB is faulty..
but I don't know where is the problem.
Willy told me change FLASH ROM.. but I don't have flash ROM for NOKIA 9210.
Best Regards,
Wahab
Old 02-26-2004, 23:09   #9 (permalink)
rambo amadeus's Avatar
Member: 8208
Thanks Meter: 24
DrMobile,
have you solved this fault or no?
Now I have this one like your 9210.PDA work perfect but phone no power on.
Thx and regards.
Old 04-22-2004, 23:44   #10 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
first test flex connector (is easy and quick to see with microscope)
because I don't know how to test 9210 board, If this problem would mine... I would change most possible faulty components... first reflow/rebouling or change ccont. If ccont don't repair phone then I suspect from flash ic... I think the phone flash ic (not the pda) would be the same like any phone from same time of 9210 manufacture (3310,8210,8850)... monday I will compare flash ic's and will tell u a request
I know that I don't help you a lot... but I will try
best regards
Old 04-23-2004, 13:55   #11 (permalink)
Member: 8208
Thanks Meter: 24
Thx m8 for your answer,
I have change flex and problem solved.
Best regards.
Blackberry PDA and GSM phone Burnt Cobba BlackBerry (RIM) 11 09-08-2010 09:48
Power sourse is working, but the handel is not heating candra_yus Tornado Infra Station 12 07-28-2007 18:36
Gsm Phones & Pda Appz For You. TRABEL Nokia Multimedia 3 10-31-2005 11:52
I Have T100 Every Thing Is Working But Phone Is Not Connecting Call OSSIE VLSI, Conexant, Skyworks and Old Models 3 05-16-2003 19:52
Page generated in 0.20892 seconds with 9 queries
