01-08-2010, 22:33 | #1 (permalink) |
Junior Member Join Date: Apr 2005 Age: 49
Member: 139059 Status: Offline Thanks Meter: 1 | n95 8g phone start-up failed contact the retailer P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.22.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia HW version: 4120 PCI version: RFIC version: 17141715 DSP version: aino_mc.ICPR62_08w28 Retu version: 15 Tahvo version: 22 Production serial number: SHG437010 Product code: 0557631 Module code: Basic production code: 0548236 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 356842020368622 IMEI spare to net: 3A 65 48 02 02 63 68 02 IMEI SV to net: 33 65 48 02 02 63 68 12 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-320.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0557631 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ Searching for default location of ini... Checking path: \Products\RM-320\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
01-09-2010, 11:43 | #6 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Quote:
The Following User Says Thank You to ashraf_bcs For This Useful Post: |
Nokia N95 rm159 phone start-up failed contact the retailer [ Solved ] | mariaperezkkk | Cyclonebox | 19 | 03-30-2010 00:04 |
n95 8g phone start-up failed contact the retailer | sfeansfean | Cyclonebox | 3 | 01-09-2010 20:30 |
Nokia N95 8g PHONE START UP FAILED CONTACT THE RETAILER | biscotte64 | Nokia Base Band 5 ( BB-5 ) | 9 | 08-22-2009 20:54 |
N95 8G Phone start-up failed.contact the retailer | yx724 | Nokia Base Band 5 ( BB-5 ) | 4 | 04-30-2009 17:26 |
N95 8g phone start-up failed contact the retailer | miguel_john1975 | Nokia Base Band 5 ( BB-5 ) | 15 | 04-13-2009 11:35 |
