Old 12-22-2009, 22:05   #1 (permalink)
Member: 678448
Thanks Meter: 25
N95 8GB Auto Charging Pls Help
N95 8gb just on the set wight light...
i heat the processor and rapido ic set is working normally
no water damage before i have a one problom..
when i put battary. Auto Charging ..and i put the Charge Charging not responsibil.
any one have the solution.. Pls Help me....
The Following User Says Thank You to sarjoon For This Useful Post:
Old 12-22-2009, 22:35   #2 (permalink)
Member: 203352
Sonork: 100.1609650
Thanks Meter: 244
betty is problem change it
Old 12-23-2009, 12:15   #3 (permalink)
Member: 678448
Thanks Meter: 25
chenged the betty ic more then 3 time same problem
the set is same Auto Charging any other solution.. Pls Help.. thanks
Old 12-23-2009, 14:23   #4 (permalink)
ranji's Avatar
Member: 670594
Thanks Meter: 51
chk avilma also some times sensing prblmm
Old 12-25-2009, 13:35   #5 (permalink)
Member: 678448
Thanks Meter: 25
thanks... i chenged the avilma now Auto Charging.. problem solved thanks. but Charge not responsibil
i checked Charging line is ok..... Charging doesn't work
any solution.. Pls Help me.......
Old 12-26-2009, 22:30   #6 (permalink)
Member: 678448
Thanks Meter: 25
no one Help for me..
Old 12-30-2009, 17:56   #7 (permalink)
Member: 535650
Thanks Meter: 13
chang betty ic from ani other pcb it wark 100% bikos its og
Old 12-31-2009, 14:28   #8 (permalink)
Member: 678448
Thanks Meter: 25
thanks for advest now phone is dad how many times i chenged betty ic
k530i auto charging pls help yadwinder Sony Ericsson Hardware Repair 2 02-01-2010 11:45
N95 8GB Auto Charging Pls Help..... sarjoon Nokia Hardware & Hardware Repair 0 12-22-2009 15:02
n95-8gb auto shot off help arabie Cyclonebox 4 12-17-2009 07:11
T100 auto charging Pls help !!!! FAIZAN_FLASHER Samsung Hardware Repair 1 12-07-2005 14:00
MC 920 auto charging pls help??? proxy_gsm Sagem Hardware Repair Area 1 10-06-2003 22:17
Page generated in 0.17272 seconds with 9 queries
