Old 07-03-2009, 08:08   #1 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
N95 8GB blank Display key pad light on
N958gb lcd light Blank no light no display
The phone switches on, only keypad light on only there is nothing on the screen, its as if it's switched off The phone switches on.
i change the flex and lcd but still the same, i try to also change onther mother board to my flex or lcd work fine so plz give me tested working solution
The Following 3 Users Say Thank You to mohit_kripalu01 For This Useful Post:
Old 07-03-2009, 08:21   #2 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
here is pic
Old 07-03-2009, 12:34   #3 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
no reply that mean no solution
Old 07-03-2009, 13:36   #4 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
have you try display ic ???
have you chk flexi connector to light ic way,,,maybe that is fault....
rehot the connector or replace the display ic,,hope solve it,,,
post result
Old 07-04-2009, 01:18   #5 (permalink)
Registered User
Member: 804452
Thanks Meter: 249
change rebun (patta) ur problam 100% solve ok
post result ok
Hariom
Old 07-04-2009, 03:18   #6 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
solution is here
u need to replace L4403, do not use the old Flex. cause is u change L4403 and u use the old Flex, L4403 will be damaged again.
and if u try another flex without replacing L4403 the new flex will be shorted .
so the solution is to replace L4403 and change a new Flex.
br
The Following 11 Users Say Thank You to BouRRi_GSM For This Useful Post:
Old 07-04-2009, 08:18   #7 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
post result
Originally Posted by BouRRi_GSM View Post
solution is here
br
i try this same problem vibrate , keypad light on only no statup tone no disply light..........?
The Following User Says Thank You to mohit_kripalu01 For This Useful Post:
Old 07-04-2009, 16:23   #8 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
try connect phone to any flasher box and check connection and if u can read phone infor or not?
br
Old 11-13-2009, 08:20   #9 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
solution is here
br
this solution is worked well 100% thank you
The Following 2 Users Say Thank You to MPhoneClinic For This Useful Post:
Old 02-26-2010, 11:47   #10 (permalink)
Member: 395587
Thanks Meter: 63
solution is here
br
Great job thnx a lot!
The Following 2 Users Say Thank You to lasty For This Useful Post:
Old 03-18-2010, 16:40   #11 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 603
solution is here
br
1000000% working solution bro............
br.
<<<<hanif007>>>>
The Following 2 Users Say Thank You to hanif007 For This Useful Post:
Old 03-24-2010, 06:45   #12 (permalink)
Member: 772932
thankyouuuuuuuuuuuuuuuuuuuuuuuuuu %100
Old 04-03-2010, 00:33   #13 (permalink)
Member: 186289
Thanks Meter: 25
1000000000000000000000000000% work with me thanks
only short it to vbat and phone is work again with old flex too(maybe im luck)
thanks
Old 05-30-2010, 14:02   #14 (permalink)
Member: 848921
Thanks Meter: 3
thanks
wot is vbat bro where i can find on the mother board...regards:aslams...thanx
The Following 3 Users Say Thank You to aslams For This Useful Post:
Old 06-13-2010, 16:22   #15 (permalink)
Member: 794008
Gud Gud thank u ..... 100% working
The Following User Says Thank You to Mohammed sameer For This Useful Post:
N95 8GB black Display key pad light on mohit_kripalu01 Nokia Base Band 5 ( BB-5 ) 18 12-20-2010 09:19
5300 no display and key pad light DIN231080 Nokia Hardware & Hardware Repair 5 12-12-2010 16:15
1110i made in china no display and key pad lights plz help asif_ae Nokia Hardware & Hardware Repair 0 06-22-2009 13:29
6680 display & key pad lights problem DigitalMan Nokia Hardware & Hardware Repair 0 05-15-2008 11:31
6610 no display and key pad lights tajinder Nokia Hardware & Hardware Repair 0 02-17-2006 17:09
Page generated in 0.29049 seconds with 11 queries
