Old 10-11-2009, 07:10   #1 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
n95 8gb discharge battery
hi
2 all. my cell n95 8gb battey was discharge (approx 6hours only) i fully charged battery, but without any making calls battery is discharged. some times battery goes to 2v only. i gussed some shorting but i did'nt find where the place (phone is everything ok, battery is ok.) it is not water damage.
plz any one help me
thank you
Old 10-11-2009, 07:12   #2 (permalink)
.:Baby @ngel:.'s Avatar
Member: 1134393
Sonork: 100.1607778
Thanks Meter: 59
you just try to program sir.....
latest version..............
or maybe the phone is grounded...........
Old 10-11-2009, 07:25   #3 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
Originally Posted by kiran View Post
hi
plz any one help me
thank you
change charging ic ( betty )
and poet result
Br,
Old 07-17-2010, 08:47   #4 (permalink)
Member: 77706
Thanks Meter: 26
same problem, latest version, replaced betty, no result.any other ideas ?
Old 07-19-2010, 17:49   #5 (permalink)
Member: 395587
Thanks Meter: 63
Change avilma as well but first always should check the media button on the side if it`s pressed(common when the housing is a fake one) and u can also switch the integrated gps off too and then check other things (like betty etc.) when is still the same.
The Following User Says Thank You to lasty For This Useful Post:
Old 07-20-2010, 09:23   #6 (permalink)
kashantariq2002's Avatar
Member: 1019981
Thanks Meter: 98
first bro you chech your mobile there is shortage or watere and cleann your pcb then check
Old 07-20-2010, 09:52   #7 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
bro change walanpa ic set 100% ok I am tested
Old 08-06-2010, 17:27   #8 (permalink)
abdaouicom's Avatar
Member: 236295
Thanks Meter: 38
wath this ,,,,,,??????????? shemat please
Old 08-06-2010, 17:57   #9 (permalink)
Member: 395587
Thanks Meter: 63
Wlan ics(for wireless).
Which is a good idea to check when u can`t find where the board is discharging the battery.
Old 08-07-2010, 05:55   #10 (permalink)
Member: 598084
Thanks Meter: 9
change betty ic that responsiple of fake chrge
Old 08-07-2010, 06:46   #11 (permalink)
Member: 53180
Thanks Meter: 11
if its still the same problem, then replace your flex cable. sometimes it shorts to ground.
Old 08-07-2010, 08:05   #12 (permalink)
Member: 783336
Thanks Meter: 21
i also was suffer this problem... but now i solve this .... change battery flash ur set than i change some setting in fone... like light sensor. minimum and power saver time less than 30 sec.. a more option is network mode... use gsm mode......
Old 10-30-2010, 14:34   #13 (permalink)
abdaouicom's Avatar
Member: 236295
Thanks Meter: 38
plazzzzzzzzzzzzzz shemat thankssssssssssssssssssssssssssssssss
need help master manole n95-8gb write screen restart haslyn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-30-2010 10:56
N95 8GB Simlock GSM-Telecom MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-30-2010 03:27
N95 8GB low battery power off after 1 hour shy100 Nokia Base Band 5 ( BB-5 ) 3 03-18-2010 18:17
N95 deth after battery discharges ??? cmek HWK 5 08-08-2009 20:57
Nokia N95 8Gb draining battery Wynsak Nokia Hardware & Hardware Repair 6 06-05-2009 08:36
Page generated in 0.17530 seconds with 10 queries
