n95 8GB sometimes show insert simcard or sim card regitration failed hi i got a n95 8gb. sometimes its show registartion failed or insert simcard even simcard in the phone. whats can be problem? its software or hardware problem. thanks |
try to change sim ic |
change sim ic & your problem is solved 100% |
where is sim ic?can plz send me pic? |
change da two registance, by da sim reader ur problem will be sloved 100% |
hallo try to give peaple write answer try to downgrade the phone and uppgrade with factory setting and will be ok that is for sim card valid solution thanks |
there's no sim ic in that phone, try clean the sim connector orfull factory... maybe it will help ur problem. |
this phone sim driver is avilma .... this is power controler ic change this ic i am tested this. |
Where is avilma please i don't find it ? Thank you very much |
where is sim ic?can plz send me pic |
this phone without sim ic,,,, you just reball or replace avilma |
First change battery and check |
check sim tray............then change avilma(power ic).............. |
