Old 05-22-2008, 20:42   #1 (permalink)
mobileunlockers's Avatar
Member: 396778
Thanks Meter: 151
n95 8GB sometimes show insert simcard or sim card regitration failed
hi
i got a n95 8gb. sometimes its show registartion failed or insert simcard even simcard in the phone. whats can be problem? its software or hardware problem. thanks
The Following 2 Users Say Thank You to mobileunlockers For This Useful Post:
Old 05-22-2008, 21:25   #2 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 958
try to change sim ic
Old 05-26-2008, 10:09   #3 (permalink)
Member: 614097
Thanks Meter: 24
change sim ic & your problem is solved 100%
The Following User Says Thank You to hajipur For This Useful Post:
Old 06-25-2008, 15:42   #4 (permalink)
Member: 719309
where is sim ic?can plz send me pic?
Old 05-26-2009, 23:18   #5 (permalink)
Registered User
Member: 652293
Thanks Meter: 19
change da two registance, by da sim reader ur problem will be sloved 100%
Old 05-29-2009, 18:48   #6 (permalink)
Member: 602754
Sonork: mr
Thanks Meter: 5
hallo try to give peaple write answer
try to downgrade the phone and uppgrade with factory setting and will be ok
that is for sim card valid solution thanks
Old 05-29-2009, 18:49   #7 (permalink)
Member: 602754
Sonork: mr
Thanks Meter: 5
Originally Posted by mobileunlockers View Post
hi
Old 08-13-2009, 10:13   #8 (permalink)
Member: 736901
Thanks Meter: 11
there's no sim ic in that phone, try clean the sim connector orfull factory... maybe it will help ur problem.
Old 08-13-2009, 10:25   #9 (permalink)
Member: 857624
Thanks Meter: 20
this phone sim driver is avilma .... this is power controler ic change this ic i am tested this.
Old 08-31-2009, 17:23   #10 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
Where is avilma please i don't find it ? Thank you very much
Old 11-25-2009, 06:28   #11 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 313
Old 11-25-2009, 06:32   #12 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,540
this phone without sim ic,,,,
you just reball or replace avilma
Old 11-25-2009, 06:57   #13 (permalink)
Don_R's Avatar
Member: 256801
Thanks Meter: 45
First change battery and check
Old 11-25-2009, 08:33   #14 (permalink)
aravimobile's Avatar
Member: 602589
Sonork: 0000001
Thanks Meter: 819
check sim tray............then change avilma(power ic)..............
Old 11-25-2009, 09:49   #15 (permalink)
Member: 1159408
Thanks Meter: 9
have not sim ic. replace avilma
6300 sim card registration failed!!! ..::khaled::.. Nokia Hardware & Hardware Repair 16 07-19-2011 17:00
n95 8gb sometimes hang and sometimes blank ahmad5175 Nokia Base Band 5 ( BB-5 ) 5 03-11-2010 07:47
n95 8gb sim card registation failed after unlock okrongly BB5 Box by D.K. 10 03-05-2009 23:47
Chinese Nokia n95 8gb restart when insert sim???? svchost Infinity-Box 1 02-05-2009 13:17
6600 Alway Shows Sim Card Registration Fail GOODNESS WD2 & APE (Symbian Phones) 14 12-02-2006 10:37
Page generated in 0.50493 seconds with 8 queries
