09-21-2008, 13:04 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 727908 Status: Offline Thanks Meter: 10 | N95 8GB Will not charge I have an N95 8GB which has got a little water damage on it. The phone works fine except it will not charge. I used electronic clensing fluid on the mainboard and dryed it in rice for two days, but the phone will still not charge. Does anyone have any ideas or solutions to this problem? |
The Following User Says Thank You to Oleq83 For This Useful Post: |
09-21-2008, 14:14 | #3 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: UNITED ARAB EMIRATES Age: 41
Member: 760274 Status: Offline Thanks Meter: 146 | Quote:
PLEASE GO TO THIS LINK:;;;;;;;;;;;;;;;;;;; http://forum.gsmhosting.com/vbb/show...t=N95+CHARGING THEN POST RESULT..................... | |
The Following 4 Users Say Thank You to NIMESHFONOTLY For This Useful Post: |
09-22-2008, 12:36 | #5 (permalink) |
Member: 727908 Status: Offline Thanks Meter: 10 | Ok. So I checked the charger connectors on the mainboard and there seems to be going electricity through the phone, because I could get an indication that there was running electricity when I connected a measurment device to it. I couldn't measure exactly how much voltage there was when the charger was connected, because I couldn't access that area when it was connected. But I used an instrument that gives a "beep sound" when there is a connection, so I used this without the charger connected. So it seems that the track is fine. Could it be a software problem perhapse, or could it be an IC problem? if so is it possible to replace it? |
10-15-2008, 15:26 | #10 (permalink) |
Member: 727908 Status: Offline Thanks Meter: 10 | I've tested the phone now with a charged battery. I left the battery in the phone overnight with the phone turned of and noticed the next day that the battery had been severely drained during the night. Also the battery wont last more than a day at max with the phone turned on. It seems like there is a short circuit or something inside the phone. |
03-01-2009, 00:18 | #11 (permalink) | |
Junior Member Join Date: Jan 2008 Location: united kingdom
Member: 692646 Status: Offline Thanks Meter: 5 | Quote:
saqib | |
The Following User Says Thank You to sendo For This Useful Post: |
02-28-2011, 23:56 | #12 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1526980 Status: Offline Thanks Meter: 0 | nokia n95 gb water damage My phone fell in saltwater.. i took the battery out opened the phone dried it . worked fine for 2 days.. my phone does not charge.. tried diff. charger stil wont work.. when i plug the charger in it says not charging tried my car charger also not work. the phone lights up when i insert the charger. if the phone is of the charge lines runs for 5 seconds then stops.. is there a way to save the phone? please help regards Eugene |
N95 8Gb never stops charging. Drains battery fast | Crazy_ratata | Nokia Hardware & Hardware Repair | 2 | 09-13-2008 08:07 |
n95 8gb probelm with charging | waelkawasaki | Chinese Models & Cloned Phones | 0 | 09-01-2008 01:27 |
C55 will not charge | HONGXING | E-Gold Based Phones | 10 | 09-20-2006 21:45 |
7250 will not charge | leemobile | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-20-2004 01:19 |
T 191 e will not charge | Templar_spook | Motorola ODM | 1 | 09-04-2003 10:32 |
