06-20-2008, 06:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: mobile world Age: 49
Member: 42370 Status: Offline Thanks Meter: 32 | n95 auto restart..... any one got the solution???? please sharing for me.. thanks advance |
The Following 3 Users Say Thank You to smartecs For This Useful Post: |
06-20-2008, 10:18 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | That was the software fault bro try to flash the phone with JAFyour problem is solved. Post a result. Thankz. Xtreme Mobile. BRB. |
The Following 2 Users Say Thank You to Vijendra Saini For This Useful Post: |
06-20-2008, 11:44 | #3 (permalink) | |
Member: 42370 Status: Offline Thanks Meter: 32 | Quote:
try many time on software already ... result same... eraese bin or format try same problem also...... when you continous on using camara it will restart | |
The Following User Says Thank You to smartecs For This Useful Post: |
06-20-2008, 12:36 | #4 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | Quote:
hi m8t if u have all try software no good result .so check the flux cabel i hope problem in which caz i have solved this problem i hope if a problem flux cabel so 100% solved this problem . Best Regard. BR IKRAM BUTT | |
The Following 3 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post: |
06-22-2008, 12:56 | #6 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | Hello Hi, When You Connect Phone To Jaf Box, Does Phone Go Into Test Mode. If You Can Put Phone To Test Mode Through Fbus Cable, Try Using Sx4 Server And Write Pm Without Field 308. Have A Nice Day. |
The Following User Says Thank You to ahmedksal For This Useful Post: |
06-23-2008, 15:28 | #7 (permalink) | |
tested~~afetr write pm using sx4... camara problem non often happen.. but once use gps get auto restart | |
06-24-2008, 06:08 | #8 (permalink) |
Freak Poster Join Date: Dec 2002 Location: ****land full of cheater Age: 48
Member: 18948 Status: Offline Thanks Meter: 53 | Problem found in RETU to BSI line. BSI fault causing these kinda problem. I sloved 2 N95 4gb by simply hehot the Retu. and another one by resoldering the batt connector. The Bsi connection was dry. |
The Following 2 Users Say Thank You to tanim_1976 For This Useful Post: |
06-24-2008, 06:40 | #9 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268930 Status: Offline Thanks Meter: 23 | This is not software problem caz i have also sam problrm in N95 i think this problem is in Hard drive or camera i m trying also to solve this problem if any one have tested solution pleas shere it here thanks for all |
The Following User Says Thank You to skd_123 For This Useful Post: |
06-24-2008, 19:04 | #10 (permalink) |
No Life Poster Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | yes, n95 HW 6025 this restarting problem, i tested all software versions, 21***x,20***x,12***xx all same not success. yesterday i checked with RPL ,sx4 write pm all same condition regards, saif |
The Following 2 Users Say Thank You to saif@cellplus For This Useful Post: |
06-24-2008, 20:05 | #11 (permalink) | |
Insane Poster Join Date: May 2008 Location: doha Age: 39
Member: 775684 Status: Offline Sonork: [email protected] Thanks Meter: 9 | n95 Quote:
The Following User Says Thank You to sarassaras For This Useful Post: |
06-26-2008, 08:21 | #14 (permalink) |
Member: 268930 Status: Offline Thanks Meter: 23 | So what is solution?? any master pleas help here we are waiting for a strong solution pleas don't post any non tested idia |
n95 rm-159 auto restart after some minutes or seconds | pakmobiles | Universalbox | 2 | 11-11-2009 12:39 |
N95 auto restart??? | myangle | Nokia Hardware & Hardware Repair | 2 | 10-20-2008 08:44 |
N95 auto restart | terry96 | Nokia Hardware & Hardware Repair | 9 | 09-14-2008 10:19 |
N95 auto restart somtime | Sin chanthoeurn | Nokia Hardware & Hardware Repair | 3 | 07-21-2008 18:03 |
n95 jammed then auto restart ,,,,help me | vijaya7668 | Nokia Hardware & Hardware Repair | 4 | 05-05-2008 04:19 |
