Old 06-21-2008, 09:41   #1 (permalink)
Member: 222583
Thanks Meter: 32
N95 Front Camera "Unexpected Error" Any solution ???
Hi friends.
I have N95 when i opened front camera message apperared " Unexpected Error " any solution ?
Best Regards.
Old 06-21-2008, 10:10   #2 (permalink)
Member: 5358
Thanks Meter: 211
replace the slide habebe
Old 06-21-2008, 10:22   #3 (permalink)
Member: 222583
Thanks Meter: 32
friend i replace flat and slide , the same problem .
Thanks for reply.
Old 06-21-2008, 11:00   #4 (permalink)
Member: 5358
Thanks Meter: 211
reassemble the phone check if there is a liquid damage , check also if the phone main camera is working , check also the version of the software
Old 09-28-2008, 16:00   #5 (permalink)
Member: 83575
change z5400 or z5401
Old 10-06-2008, 18:00   #6 (permalink)
Crazy Poster
Member: 653708
Thanks Meter: 12
N95 front camera
which model is same for that ic
Old 02-04-2009, 21:23   #7 (permalink)
turktwister's Avatar
Member: 84208
Thanks Meter: 25
Originally Posted by ales6orah View Post
Hi friends.
Best Regards.
i think it may cause because of camera slide.i repair some pieces
Old 02-04-2009, 21:41   #8 (permalink)
nokia-ps's Avatar
Member: 801286
Thanks Meter: 54
my brouther im made to this wrong im changed lcd working 100%
B.R
Old 02-11-2009, 15:48   #9 (permalink)
Member: 125350
Thanks Meter: 13
Hello all,n95 1 gb front camera not working..unexpected failure msg.any solution?
Old 10-17-2009, 16:49   #10 (permalink)
Member: 1046352
is this caused by firmware?? there are some n 95 with same trouble....
Old 10-17-2009, 16:50   #11 (permalink)
Member: 1046352
also waiting for solutions........
Old 01-30-2010, 17:30   #12 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
chek its dcc file ??? with mx key
his dcc file is miss
write dcc file ur problem will be slove 100% after write dcc file
Old 01-30-2010, 18:31   #13 (permalink)
Crazy Poster
Member: 633567
Thanks Meter: 12
N95 no file dcc, chek hw
Old 03-04-2010, 20:34   #14 (permalink)
Member: 783599
hi
could you tell me what is dcc file and if this file is missing where i can download this file
The Following User Says Thank You to farhanmuzaffer For This Useful Post:
Old 03-22-2010, 21:42   #15 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
this is double chip ic ,,heat with care little bit,,,will be ok,
N95 Front Camera Problem coolgsm007 Nokia Hardware & Hardware Repair 9 08-27-2010 04:33
n95 front camera problem SHABAD TK Nokia Hardware & Hardware Repair 1 01-26-2009 11:57
N95 Front Camera "Unexpected Error gezgin27 Nokia Hardware & Hardware Repair 2 10-30-2008 11:00
N95 front camera not working audvid2_bd Nokia Hardware & Hardware Repair 3 07-09-2008 11:49
Page generated in 0.22775 seconds with 10 queries
