03-01-2008, 07:37 | #17 (permalink) |
Major Poster Join Date: Jan 2006 Location: Mombasa
Member: 220742 Status: Offline Sonork: None Thanks Meter: 2 | Can you please tell us about anyother way to solve this problem.As it's behaving strange in that keypad lights on and off.Should it be a software solution? Please help me am stuck and dont know what to replace next.Thanks while somebody have talked about the YELLOW CAP where is this? |
03-01-2008, 07:49 | #18 (permalink) |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | ALL BB5 VERY VERY LETEST HARDWARE-REPAIR AREA ONLY RECENT PROBLEM AND DAYLE UPDATE !!! ************* |
03-01-2008, 08:50 | #19 (permalink) |
Member: 220742 Status: Offline Sonork: None Thanks Meter: 2 | I have just realized that this N95keypad lights on/off depends on the sensor right above the upper camera which detects if there is not enough light then keypad lights on and when there is enough light they dont light up at all.dont you start changing I'c n capasitors trying to repair this unless you compleately dont have your display lights on,then change the upper block in Shara191 thread.Thaks n enjoy. |
03-01-2008, 08:56 | #20 (permalink) |
Member: 220742 Status: Offline Sonork: None Thanks Meter: 2 | I have just realized that this N95keypad lights on/off depends on the sensor right above the upper camera which detects if there is not enough light then keypad lights on and when there is enough light they dont light up at all.dont you start changing I'c n capasitors trying to repair this unless you compleately dont have your display lights on,then change the upper block in Sharaz191's thread.Thanks n enjoy. |
06-16-2008, 00:07 | #27 (permalink) |
Junior Member Join Date: Jul 2007
Member: 540103 Status: Offline Thanks Meter: 0 | when you remove the yellow cap everything work. i dont know where i can find the replacement for yellow cap. my question is if i dont put the new yellow cap into the board will that cause problem? anyone know please answer for me. |
06-23-2008, 18:52 | #29 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 50
Member: 72774 Status: Offline Thanks Meter: 3 | Check this post --------> http://forum.gsmhosting.com/vbb/showthread.php?t=543358 |
The Following User Says Thank You to smartgsm30 For This Useful Post: |
06-27-2008, 04:25 | #30 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Hello FRDZ... i have problem wit h LCD light !!! Light obtaining BELOW i.e keypad below light coming OK!!! but the LCD and KEYPAD Up lights not comming!! can you give me a solution for this PROBLEM !!! ANd with PICTURES if possible !!! Thank you !!! |
n95 no light in slide part | jo1968 | Nokia Hardware & Hardware Repair | 40 | 02-05-2012 20:24 |
N95 No light | sood | Nokia Hardware & Hardware Repair | 5 | 10-27-2008 17:57 |
n95 No Light and LCD Display on the sliding part.! Help! | vanbritz | Nokia Hardware & Hardware Repair | 1 | 09-06-2008 07:41 |
n95 no light | kcponsel | Nokia Base Band 5 ( BB-5 ) | 1 | 08-31-2008 11:51 |
Nokia N95 no lights in LCD | haveri | Nokia Hardware & Hardware Repair | 10 | 09-21-2007 18:36 |
