Old 06-12-2010, 06:48   #1 (permalink)
Member: 1108823
Thanks Meter: 20
n95 rm-159 strange keypad
sir i have received a set n95 in which when i switch on the phone only one keypad press the set is in hang position & only keypad sound without press keypad but actually not in hang,because set is going to off when i press on/off switch but not press other switch.
i change keypad ic
i remove volume switch,camera switch
but result is same
sir i want to know that where is the problem,is it software or hardware?
thanks in advance
Old 06-12-2010, 06:55   #2 (permalink)
Member: 1108823
Thanks Meter: 20
please sir reply soon it's very urgent
Old 06-12-2010, 07:34   #3 (permalink)
Member: 1108823
Thanks Meter: 20
nobody have a single answer?
Old 06-12-2010, 07:39   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
i change keypad ic
but result is same
thanks in advance
Bro.1st try to flash.....
result post here.
Old 06-13-2010, 09:13   #5 (permalink)
Member: 1108823
Thanks Meter: 20
result post here.
sir i flash set with hwk but ui setting failed but set is in same condition
Old 06-13-2010, 12:51   #6 (permalink)
Member: 1108823
Thanks Meter: 20
sir please give me some solution
Old 06-13-2010, 16:23   #7 (permalink)
Member: 1108823
Thanks Meter: 20
anyone expert who,s help me
Old 06-13-2010, 17:38   #8 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.1st chack flex cable
2nd.replace original keypad ic
3rd.chack vilume key track.
try this solution one by one.
Old 06-29-2010, 04:21   #9 (permalink)
Member: 810098
Thanks Meter: 35
It is possible do an JUMPER without using the replacement? because I have no plate in this model junk
Who can help me?
Old 07-01-2010, 01:05   #10 (permalink)
Member: 498132
Thanks Meter: 15
I have same problem any one help us?
Old 07-01-2010, 03:45   #11 (permalink)
Member: 498132
Thanks Meter: 15
i change keypad ic
but result is same
Old 07-01-2010, 04:24   #12 (permalink)
Member: 895524
Thanks Meter: 33
i had same problem the other day, customers phone turns on goes into menu but none of the keys where working, ended up taking the phone apart and checking the mainboard and found water damage at the rapido chip next to the camera.
i dont know if this will solve your issue but the lesson learned from this little repair is, if all else fails just go wash your mainboard and hope for the best.
The Following User Says Thank You to kawaichang For This Useful Post:
Old 07-01-2010, 22:47   #13 (permalink)
Member: 498132
Thanks Meter: 15
Ok let me try thank
Old 07-02-2010, 07:35   #14 (permalink)
Member: 1300401
Sonork: 2+2=4
Thanks Meter: 16
dear brothers, first your phone full flash in latest file version file, and unlock in ub box or mxkey problem solved in 100 @%%%%%%%%% tested ................
Old 07-02-2010, 22:48   #15 (permalink)
Member: 498132
Thanks Meter: 15
No dont flash 100% clean main board it works for me thanxx kawaichang for solution bro keep it up
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
strange 5110 5.28 pls help Salami1_1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-02-2001 17:57
strange contact service Dark Lemming Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-12-2001 09:18
Strange Solutions... rompa Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-12-2000 17:51
Strange unlocking Dens666 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-14-2000 14:45
Page generated in 0.34115 seconds with 10 queries
