05-10-2010, 12:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Bangladesh
Member: 881225 Status: Offline Sonork: 100.1678282 Thanks Meter: 80 | n95 SECURITY_TEST failed help Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 06wk41v23.4 17-04-07 RM-159 (c) Nokia Using cached productData[04A00115E4690058644CD94CB52D1FE240D30DE8] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.0 revision 1.7 Completed in 3.813 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-159_356996013985436_SD.RPL" Updating SUPERDONGLE_KEY ...OK Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 06wk41v23.4 17-04-07 RM-159 (c) Nokia Using cached productData[04A00115E4690058644CD94CB52D1FE240D30DE8] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
05-10-2010, 13:16 | #2 (permalink) |
Freak Poster Join Date: Sep 2007 Location: FPS-21 The best nokia prommer!
Member: 590644 Status: Offline Thanks Meter: 146 | Before repair SD, repair SIMLOCK by RPL then generate a new SD RPL... Try this way...if the program return "ack problem" when autenticating the custom SD, contact MX-Key support team hope they will solve the problem if the bug is on server Freeck! |
The Following User Says Thank You to Freeck For This Useful Post: |
05-10-2010, 13:20 | #3 (permalink) |
No Life Poster Join Date: May 2009 Location: Online
Member: 1024090 Status: Offline Thanks Meter: 1,175 | Solved "SECURITY_TEST failed!" after SD repair We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...) Now all SD repair should work well. Here is general repair procedure. It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....). It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones. 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here: http://rapidshare.com/files/34542441...e_by_MxKey.zip http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip http://www.4shared.com/file/21610198...thout_NPC.html MEGAUPLOAD - The leading online storage and file delivery service anowar_virus |
The Following User Says Thank You to anowar_virus For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
