N95 Slide Sensor Problem hi, I have an n95 and want to ask about how to repair the slide sensor. I want to repair it because when I slide the display up or down it doesn't react on the screen I mean no lock functionality of the media player functionality. So now can anybody tell me how to repair or how to tweak the slide sensor? Thanks, aaho |
anybody? any small info? |
hi I have the same problem.. do you solve it?? After the change of a cover (the second change, the first was ok) the slide sensor stops to react.. thanks :rolleyes: |
the light working or not when you slide this? |
no, the light doesn't work.. I must touch the keybord to see the light :( |
oh..problem solved, I read read read again and again the service manual.. the problem is the hall magnet.. I change the ui slide and I forgot to put the magnet on it.. :P thanks all!! |
hi dear, 1st of all open ur fone slider and check is there magnet on plate...if not then put a magnet on there form other scrap slider ...ur problam will solve,,, post result |
hey guys, where exactly is that magnet located? I checked the service manual but i cant see any magnet. |
N 95 sencer Brother same problem i solve first the magant change and another is a sencer in between the side swich and another is near camera swich plese change these one solve the problem:) |
please check the orig casing theres a magnet there which u did not in clude during replacing the case. its at the back of lcd part.. |
The sensor magnet is located behind the display screen, towards the bottem right. Is a small square about 1/4 the size of a SIM card. You will need a thin blade to remove it, and prise it out. |
