Old 03-17-2009, 16:31   #1 (permalink)
Member: 429524
Thanks Meter: 3
Arrow N95 Slide Sensor Problem
hi,
I have an n95 and want to ask about how to repair the slide sensor. I want to repair it because when I slide the display up or down it doesn't react on the screen I mean no lock functionality of the media player functionality. So now can anybody tell me how to repair or how to tweak the slide sensor?
Thanks,
aaho
Old 03-17-2009, 23:08   #2 (permalink)
Member: 429524
Thanks Meter: 3
anybody? any small info?
Old 12-11-2009, 19:59   #3 (permalink)
Member: 1181588
hi I have the same problem.. do you solve it?? After the change of a cover (the second change, the first was ok) the slide sensor stops to react.. thanks
Old 12-11-2009, 22:15   #4 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,347
the light working or not when you slide this?
Old 12-13-2009, 21:13   #5 (permalink)
Member: 1181588
no, the light doesn't work.. I must touch the keybord to see the light
Old 12-14-2009, 00:00   #6 (permalink)
Member: 1181588
oh..problem solved, I read read read again and again the service manual.. the problem is the hall magnet.. I change the ui slide and I forgot to put the magnet on it.. :P thanks all!!
Old 12-15-2009, 01:06   #7 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
hi dear,
1st of all open ur fone slider and check is there magnet on plate...if not then put a magnet on there form other scrap slider ...ur problam will solve,,, post result
Old 01-22-2010, 19:23   #8 (permalink)
Member: 1176802
Thanks Meter: 5
hey guys, where exactly is that magnet located? I checked the service manual but i cant see any magnet.
Old 05-07-2010, 18:22   #9 (permalink)
Member: 932171
Sonork: 2244
Thanks Meter: 11
N 95 sencer
Brother same problem i solve first the magant change and another is a sencer in between the side swich and another is near camera swich plese change these one solve the problem
Old 05-06-2011, 03:10   #10 (permalink)
Registered User
Member: 231606
Thanks Meter: 64
please check the orig casing theres a magnet there which u did not in clude during replacing the case. its at the back of lcd part..
Old 12-05-2011, 20:32   #11 (permalink)
Member: 1701266
The sensor magnet is located behind the display screen, towards the bottem right. Is a small square about 1/4 the size of a SIM card. You will need a thin blade to remove it, and prise it out.
N95 light sensor oOXTCOo Nokia Hardware & Hardware Repair 5 07-06-2009 03:55
N95 Slide Problem coolgsm007 Nokia Hardware & Hardware Repair 0 11-25-2008 15:40
W580 slide sensor wazim187 Sony Ericsson Hardware Repair 6 10-11-2008 15:25
n95 slide dual sim problem f164 Infinity-Box 1 08-24-2008 22:39
N95 had restart problem and now have problem with sensor key Supermen! Infinity-Box 2 11-23-2007 09:23
Page generated in 0.37633 seconds with 8 queries
