04-21-2008, 13:37 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | n95 water damage-can't flash- lcd just on then hang.... Regards |
04-21-2008, 18:38 | #2 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Quote:
WATER DAMAGE IN SUCH PHONES NEEDS A LOT OF EFFORTS TO GET IT COMMUNICATING WITH THE FLASHER. HOWEVER, PHONES THAT DROPPED IN LIQUID NEED THOUROUGH CLEANING WITH METHYLATED SPIRIT OR BETTER STILL, NITRO CELLULOSE THINNER THAT HELPS REMOVE THE VERDIGRIS (PALE GREEN RUST) THAT WOULD HAVE FORMED ON THE PCB ESPECIALLY IF THE PHONE IS NOT ATTENDED TO FOR LONG. IT IS AFTER THIS HOWEVER THAT YOU CAN THEN TRY YOUR LUCK AT FLASHING THE PHONE AND YOU MAY BE VERY FORTUNATE. | |
07-18-2008, 20:32 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: bahrain
Member: 625234 Status: Offline Sonork: 100.1604070 Thanks Meter: 90 | hi i thing ur bord is little short. clean ur pcb soap water.then u must clean&dry ur bord.then u check the voltage. bord not a short applay gum and re hot power ic& flash&cpu. i think this work better the water damaged phon. |
07-18-2008, 20:42 | #5 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | Quote:
20 munite...............thats all if not solved then only flash mobile......... .:sopnil:. sopniltelecom | |
x120 samsung there is problem is just on then hang | shani72 | Samsung Hardware Repair | 2 | 07-16-2008 21:39 |
7610 water damage taking flash not getting on | monti_908 | Nokia Hardware & Hardware Repair | 4 | 03-02-2006 11:22 |
3310/8210/8250 water damage can't switch on but | dragories | Nokia Hardware & Hardware Repair | 22 | 01-05-2006 12:19 |
6510 after water damage can't turn on | Destructor | Nokia Hardware & Hardware Repair | 3 | 11-18-2003 19:18 |
8210 water damage can't switch on but... | dragories | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-29-2002 18:31 |
