N96 display problem Hi, i am having n96 without display, any solution? thanks |
post again your problem on details. |
i have n96 but it is giving me no display just black... |
first change strip........ |
I have changed it several times |
if not work try it............ http://img220.imageshack.us/img220/3569/lcd.gif |
Thanks ive already changed those, but still no luck thanks for your help |
hi reheat core ic ihave this problem solved by reheating core ic |
wich is the core ic? d4800? have you solved your problem?? i have a similar problem with n96 which powers on but nothing appears on display.. and the key light is always off and doesn't light up.. it was working correctly until i rehotted the mainboard.. (it had a problem with keypad ic) please i need help... :( |
only blank n96 i have reper only blank just vib on only no need change display and cable and ics !!!!!!!!!!!!1 problem in which OMAP just re hot normal 100% repair i have 2 and 3 pec ! |
tnx guys For this Nice topic |
what is OMAP, can you make a picture please?? i have 3 x n96 with same error, Black Display and i have to repair it.. |
1 Attachment(s) Quote:
br ikram |
ok i check it today. |
