Old 10-05-2010, 15:45   #1 (permalink)
aravimobile's Avatar
Member: 602589
Sonork: 0000001
Thanks Meter: 822
:::n97 auto charging...please help::::
have got n97 with charging problem , i soldered the charging port and now its charging fine but whenever i make a call battery logo comes on the screen n phone turns off after sometime where as the battery is fully charged.
then connect charger charging normally,disconnect charger charging bar z moved..please help me..............
The Following 2 Users Say Thank You to aravimobile For This Useful Post:
Old 10-05-2010, 15:49   #2 (permalink)
Member: 602589
Sonork: 0000001
Thanks Meter: 822
i change betty ic.............same condition...............
Old 10-05-2010, 16:40   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
1.Replace charging connector.
2.Replace avilma.
try this solution one by one.
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 10-06-2010, 16:29   #4 (permalink)
Member: 602589
Sonork: 0000001
Thanks Meter: 822
2.Replace avilma.
power ic&charging connector already chenged.................no hope.........
Old 10-06-2010, 18:51   #5 (permalink)
ANILMPLY's Avatar
Member: 1268409
Thanks Meter: 57
Remove sim jack and change the two ics near the sim connector
The Following 2 Users Say Thank You to ANILMPLY For This Useful Post:
Old 10-06-2010, 18:56   #6 (permalink)
Member: 813172
Sonork: ss
Thanks Meter: 7
cheig charging conector
The Following 2 Users Say Thank You to siyu For This Useful Post:
Old 10-09-2010, 06:52   #7 (permalink)
Member: 602589
Sonork: 0000001
Thanks Meter: 822
thanks ashad420,siyu ,ANILMPLY ...........phone z ok........full flash using phonix.................
The Following User Says Thank You to aravimobile For This Useful Post:
Old 12-30-2010, 14:14   #8 (permalink)
Member: 640391
.Replace charging connector.use only og connector
Old 12-30-2010, 14:28   #9 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
not change any thing,,,jumper from charging connector ,leg 2,,,and 3 to double resistence under sim jacket,,,post result,,,tested by me,,,many time,,
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
Sp unlocking sim - if you can get or sell please let me know andrew bennett Wanted Products 1 09-24-1999 08:43
Page generated in 0.17084 seconds with 9 queries
