Old 05-04-2013, 13:56   #1 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
n97 mini
have a n97 mini in not charging and some time fack charging i change bety ic two time but condition same any other solution for it.
Old 05-04-2013, 19:27   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
in N97mini some ic's & regulator used in charging section . so we need to check step by step for not charging or fake charging problem .
first we need to check or change usb charger ic(marked in pic) . if it's ok then we need to check or change 5v pump ic .
if still same then wee need to check or change voltage monitor ic . cause vchagre voltage pass through this ic to betty .
post result .
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Page generated in 0.16107 seconds with 9 queries
