08-09-2007, 05:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: UK Age: 45
Member: 318277 Status: Offline Thanks Meter: 92 | Need experts help!! tried flashing with all versions bt it works only for d first time after flashing n then again back to square one, Is this a hardware prob or soft!!! please help me.... [email protected] |
08-09-2007, 06:32 | #3 (permalink) |
Freak Poster Join Date: Aug 2007 Location: just learning Age: 45
Member: 560754 Status: Offline Thanks Meter: 289 | try 2 make a call!if ur phone can make a call,1st solution try 2 change lcd,if the problem is same,make sure the socket lcd on ur phone board its ok,2nd solution try 2 change display ic,just try its ok and good luck!!! |
08-11-2007, 18:51 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | flash wiz jaf only!!! if problem persist, use ****er, put soldering paste on ram ic & heat it.. post result?? |
08-12-2007, 13:15 | #6 (permalink) |
Freak Poster Join Date: Jul 2007 Location: 'round the world
Member: 561120 Status: Offline Thanks Meter: 5 | 1. Find some datasheets for the phone ... 2. Seach for the ESD chips ( should be 2 - 1 for the display , 1 for the keypad ) look like some glass type chips. 3. If the keypad is working switch the chips and check if the LCD is working and the keypad dosen't ... 4. If step 3 is ok ... find some ESD chips from other phone ( or new one ) and replace Good luck |
Please help me with chinese 8800e ARTE-software problem. I need expert help | alex_ionut2003 | Chinese Models & Cloned Phones | 1 | 05-16-2009 12:34 |
Need experts help for 6610 | mobilelink | Nokia Hardware & Hardware Repair | 1 | 11-01-2007 06:49 |
n80 water domaged need expert help | mobilom | Nokia Hardware & Hardware Repair | 1 | 04-08-2007 11:17 |
cf62 need expert help | abdelrx | S-Gold Based Phones | 15 | 06-13-2006 14:33 |
need expert help 7250I | shachash | Nokia Hardware & Hardware Repair | 2 | 12-07-2005 15:20 |
