12-06-2008, 00:12 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 225684 Status: Offline Thanks Meter: 3 | Nokia e50 "sim not valid" IMEI ok Last edited by max89; 12-06-2008 at 00:18. |
12-06-2008, 08:13 | #2 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Galle, Sri Lanka Age: 40
Member: 77943 Status: Offline Thanks Meter: 56 | Sim not Valid 1. Check SIM pins with a multimeter in 1k scale to know weather there is a short with ground. If not 2. Change the SIM ic. it'll b ok |
12-06-2008, 10:24 | #8 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | Quote:
give log file .connect jaf or ufs check info. then any person help your. | |
12-06-2008, 14:44 | #9 (permalink) |
Member: 225684 Status: Offline Thanks Meter: 3 | Reading... MCU SW version: V 4.41.41 28-06-07 RM-170 (c) Nokia. HW version: 5101 PCI version: RFIC version: Đ 17211721 DSP version: ĐSiperia_PR2_CDSP_14v53_07w23 Retu version: 32 Tahvo version: 53 Production serial number: SVJ787212 Product code: 0536128 Module code: Basic production code: 0530670 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35367********* IMEI spare to net: 3A 35 76 02 01 66 24 04 IMEI SV to net: 33 35 76 02 01 66 24 04 F9 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Searching for saved ini... Checking for file E:\Program Files\ODEON\JAF\JAF_RM-170.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0536128 Searching for JAF saved location of ini... It's after unlock with bb5 king. Still this same. |
Nokia 1100 "Sim Not Valid" | Ankit Verma | Nokia Hardware & Hardware Repair | 14 | 02-03-2015 12:19 |
Nokia 1100 Problem "sim Not Valid" | !!TOKEN!! | Nokia Hardware & Hardware Repair | 5 | 02-06-2012 22:42 |
Nokia 3100 IMEI Currpted ??????????????? Show "Sim Not Valid" | Ankit Verma | Nokia Hardware & Hardware Repair | 15 | 03-11-2008 22:36 |
N70 "sim Not Valid"-wrote Rpl-still In "sim Not Valid" | zonetrichur | Nokia Base Band 5 ( BB-5 ) | 5 | 10-05-2007 13:52 |
