Old 10-03-2007, 00:10   #1 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
need help for the 9300
i got 9300 with some error when openning message and its ok when i make format the phone using jaf . but after format when use write msg in arabic it shows english alphabet from right to left.when i try to flash the phone it shows this error
Getting MCU ID
MCU ID: 0x2142
FLASH ID0: 00EC22FA -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.00
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V3.06
20-12-04
RAE-6
(c) Nokia.
HW version: 6100
PCI version:
UEM version: 400
UPP version: 8514
RFIC version: 0203
DSP version: M2.76
Production serial number: SIF081565
Product code: 0523983
Module code:
Basic production code: 0524376
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354321004282432
IMEI spare to net: 3A 45 23 01 40 82 42 03
IMEI SV to net: 33 45 23 01 40 82 42 03 F1
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 0242752106
Phone type: RAE-6, Software version: .06, Language Pack: not available
User code: 12345
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RAE-6.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0523983
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6_h56pr3.060
ADSP Flash file: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6n4536.c02
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6n4536.l30
APE User Flash file: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6n4536.u30
Languages in ppm: English,Arabic,French
Done!
Backing up PM Field 208 as RPL...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\354321004282432_imei_back up_158310.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6_h56pr3.060
Booting phone...
MCU ID: 0x2142
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.40.00 -> Revision: 0007
Boot size is 0x0970
Boot is ready...
Flash ID is 0xFA22EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia
Loader size is 0x7C20; Loader chk: d1
Error Loading loader!
any body have any idea!!
Old 10-03-2007, 02:49   #2 (permalink)
Crazy Poster
Member: 6801
Thanks Meter: 14
have you connected also the usb-cable(dku-2) to the phone? You can't flash with fbus cable only...
Old 10-03-2007, 13:57   #3 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
thanx bro, i'll try and post result
code help for nokia 9300 needed Talha1 WD2 & APE (Symbian Phones) 4 01-01-2008 17:45
need help for nokia 9300 shrey14feb WD2 & APE (Symbian Phones) 0 07-17-2006 09:07
Sonicboy for the 9300 prodigy8 Nokia Multimedia 0 08-29-2005 10:39
Need help for the MC922 S5-D2 unlock... Mike Ho Infineon C16X M51 & ARM7 M52 BASED 5 09-26-2001 21:27
Page generated in 0.14771 seconds with 10 queries
