Old 06-03-2008, 08:33   #1 (permalink)
NAZTY's Avatar
Member: 553264
Thanks Meter: 594
Need Help With Nokia 9300i...
I have 2 Nokia 9300i's that are giving me the same probs. They switch on normal when the battery is inserted But AFTER the "NOKIA" disapears & it has booted up to 80-90% the inside lcd starts to flicker & the phones eventualy switch off. I have tried a reflow, reflash & new ribbons but the problem is still the same.
Any solutions to this???
Please help...
Thanks
Old 06-03-2008, 09:21   #2 (permalink)
NAZTY's Avatar
Member: 553264
Thanks Meter: 594
Does anyone have a solution to this?
Please help...
Regards,
Nazty
Old 06-03-2008, 09:34   #3 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
I think its software fault. if you already check with new ribbon(flex cable).
1) remove memory card and format it in pc.
2) Format it with ufs.then write pm.then full ui.
3) Flash it with higher version. hope it helps.
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 06-03-2008, 09:45   #4 (permalink)
NAZTY's Avatar
Member: 553264
Thanks Meter: 594
Hi bro,
I did try a reflash with latest package & it flashed 100% perfect. All uisetting done but format user area gives error. Will try writing pm & post results.
need help with nokia 6131 firmware help!plz fishcrap Nokia Base Band 5 ( BB-5 ) 0 09-17-2006 12:53
**Need help with Nokia 3595 calculating code pls** equinoks Phone Unlocking Codes & Maps 1 03-09-2004 07:17
Need Help With Nokia 6385 INTELLER2 Nokia Digital Core Technology 4 ( DCT-4 ) 1 01-19-2004 01:51
need help with Nokia tools weiss77 Nokia Multimedia 0 02-19-2003 13:55
Need Help with Nokia 6210 v5.02 DreamSpell Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 07-19-2001 23:28
Page generated in 0.16981 seconds with 9 queries
