Need helpe 6303 charger not supported I have 6303 charger not supported if someone have seen this problem before |
http://i48.tinypic.com/o9gxnm.jpg Quote:
I changed the resistor but same problem steel charger not supported i took the the resistor frome 6300 i need really the solutino |
I will try and post result thans |
thankkkkkkkkkkkkkkk u br |
hello , 6303c after water damage clean and rehot, all working fine except charger not supported, i tryed btemp resistor-not work i tryed put pm from post but after pwr on i have contact service , i doo backup and phone working ok but still charger not supported, somebody can help (i have only jaf) :) any reason? thanks :confused: |
if this all way could't work check battery's BSI connection |
who told u to write pm on this? this is sl3 phone bro,dont fallow fake solution of any problem apna logic lagao.send me ur handset log by mxkey and define me prob starting to end what u hav done might be i can help u thank u |
hai BROOOO WICH IS THE 6303 CHARGING PROTECTOR PLEAS SHOW THE PICHER |
previous sorry boss It is still a problem on the path to BSI ....... in which case my previous water marks ..... BSI boss checks out his line ....... from BSI connector until avilma .... but the most influence 47k resistor does his boss .... wrote it thank you .... good luck .... |
6303c was facing the same problem but solved via writing PM now not saving the charging i think hardware :( |
