02-22-2007, 15:01 | #1 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 38
Member: 102996 Status: Offline Thanks Meter: 0 | Need major help with nokia 6101 When I put in the sim card and enter my pin it asks for a restriction code. I've tried several codes but none work. Imei is 357589003736981 Type RM-76 Made in hungary and inside the phone there's written "T-MOBILE D NET" I dont really know what country the phone is locked to, but there's T-Mobile written on the phone. Second question is when I enter the codes with sim card inside do I just enter the code or do I add the pw+ sings too ? When I enter the code with the pw+ signs without the sim card in phone nothing even happens, it doesn't do anything. Or maybe when I put in the codes with the simcard in phone it doesnt work because i have tried over 5 times ??? Who can help ? |
02-22-2007, 15:45 | #2 (permalink) |
Freak Poster Join Date: Dec 2004 Location: BiH Age: 43
Member: 100770 Status: Offline Thanks Meter: 57 | I dont knoe how you can calculate codes without knieing from which country the phine is!! If its not working then you should use HWK i gues, it shouldnt be that expensive!! |
02-23-2007, 04:18 | #4 (permalink) |
Registered User Join Date: Feb 2007 Location: cuba
Member: 449448 Status: Offline Sonork: flush_lever Thanks Meter: 70 | try unlock by using UFS-HWK then connect the phone and click init simlock..after several second your phone will be unlock....goodluck bro! |
02-23-2007, 06:59 | #5 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 308760 Status: Offline Thanks Meter: 47 | 6101 Quote:
#pw+ 796 290 213 434 503 +1# #pw+ 446 937 066 421 247 +2# #pw+ 758 100 070 673 711 +3# #pw+ 158 144 275 673 557 +4# #pw+ 236 305 251 425 311 +5# #pw+ 745 890 266 330 403 +6# #pw+ 809 931 527 721 443 +7# | |
02-24-2007, 02:09 | #10 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | was the phone working before ? IF yes than phone is not locked but either software problem .. try to full flash it and write a good PM and ui settings and phone will be ok ,, if not u have to check the Imei if ??????????... than definitely UEM damaged ,,, Mike |
help with nokia 6101 and 6020 | welfreng | Universalbox | 0 | 12-09-2007 03:39 |
i need help for nokia 6101 no display(lcd) | chronic | Nokia Hardware & Hardware Repair | 2 | 11-23-2007 15:58 |
need some help with nokia 6280 and phoenix | skoota121 | Nokia Base Band 5 ( BB-5 ) | 2 | 12-20-2006 05:19 |
Need Serious Help With Nokia 6230 | ummmz | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 04-03-2006 10:15 |
Help With Nokia 6101 | drgmobile | Federal One | 2 | 09-14-2005 12:19 |
