Old 09-02-2010, 17:35   #1 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
need nokia 1208 not charging soloution
dear when i attach charger first it is paused.after few times it is show not charging.pls help
Old 09-02-2010, 18:26   #2 (permalink)
SADHANBD's Avatar
Member: 1163994
Thanks Meter: 110
BR,
write good pm & unlock
Old 09-02-2010, 18:50   #3 (permalink)
Member: 1006853
Sonork: 100.1593559
Thanks Meter: 16
1200 not charging
dear remove contact service parts
dual ciramic
100%tested
Old 09-02-2010, 19:06   #4 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
Originally Posted by SADHANBD View Post
BR,
brother is it software problem , are u sure %
Old 09-02-2010, 19:21   #5 (permalink)
Member: 1276771
Thanks Meter: 33
brother clean the charging jack ant battery conector with good quality ctc
after that if not solved the problem then follow this
1200 Not Charging Problem | repair-mobiles.com
mohd_javeed_aminy
Old 09-03-2010, 05:19   #6 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
i allready done this job.
1.erasse the phone
2.flash with good pm and unlock
3.remove charging ic
4.change charging ic
5.make charging ic jumper
6.change R22
7.remove bsi local mode resistor
8.also change bsi local mode resistor
9.change 1.2 k
10.remove beside diode of battary connector
still problem is same.so i m confused what's the actual problem.because i allready solve many not charging problem in this method but it is not solved.
pls help
Old 09-03-2010, 21:50   #7 (permalink)
Registered User
Member: 1087294
Thanks Meter: 252
bro finally its uem problem so if u can
than try to change uem
The Following User Says Thank You to bruightmobile For This Useful Post:
Old 09-04-2010, 05:30   #8 (permalink)
Member: 1051906
Sonork: 44448
Thanks Meter: 130
bro u chack the battery?????
Old 09-04-2010, 06:09   #9 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
thanks for say ur comments.but i allready try with many battary
Old 09-04-2010, 08:59   #10 (permalink)
Member: 646753
Sonork: spider
Thanks Meter: 6
bro all things r ok.......
u try to change charger??????
Old 09-04-2010, 09:05   #11 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Just write good pm file only.
Old 09-04-2010, 10:11   #12 (permalink)
Member: 212014
Thanks Meter: 27
just remoove small glass ic above charging coil ur problem will be solved . check it & post reply
Old 09-04-2010, 10:45   #13 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 921
chack this ,,,,,,,,,,,,,
http://rapidshare.com/files/41699428..._charging..jpg
The Following User Says Thank You to MIRPUR AJK For This Useful Post:
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.19831 seconds with 10 queries
