Old 12-10-2010, 10:07   #1 (permalink)
Member: 102582
Thanks Meter: 72
Need Nokia 3110C Low Network Solution..
Hello Friends,
Can anyone give me the correct approach of solving the LOW NETWORK problem in Nokia 3110C set.
I have thoroughly washed the set with best quality thinner and dried it out with SMD REWORK STATION.
Blew hot air with amtech gel on the PA/PFO, HAGAR, UEM (RETU) etc.
Fully erased the software with MX-KEY and reflashed it with the latest version and wrote the 100% Ok PM file also.
THE NETWORK BAR OF VODAFONE SHOWING MAX. 3 STICKS and then going down to onely 1 stick and sometimes going off completely.
What else I could do now?
Need an expert opinion.
Advance thanks to all,
Old 12-10-2010, 10:08   #2 (permalink)
cristi_slob's Avatar
Member: 631660
Thanks Meter: 137
check antena pads
change pa
already posted 1000 times in this forum
Old 12-10-2010, 10:13   #3 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
change singel line capeciter
u r problem 100% solve
i tested it
Old 12-10-2010, 10:24   #4 (permalink)
Member: 102582
Thanks Meter: 72
Hello sahilfency,
pls. show me the signal line capacitor pls. in picture..
Advance thanks.
Old 12-10-2010, 11:09   #5 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
3110 % 6300 mostali hegar problam ribol & cheng the hegar
The Following User Says Thank You to ARIF GIGANI For This Useful Post:
Old 12-10-2010, 20:46   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,338
@amit123 ,
first of all use search button before open a thread , anyway first replace chipcap C7511 (2n2) & check.
if same replace both filters Z7501 & Z7504 , should solve ur problem.
but if not replace an****a switch Z7503 , or reball ahne rf ic.
then let me know & also post the result.
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 12-11-2010, 05:18   #7 (permalink)
Member: 392243
Thanks Meter: 6
3110, 6300
change an****a concter or remove direct
jumper
Old 12-05-2011, 00:14   #8 (permalink)
tchinidor's Avatar
Member: 422574
Thanks Meter: 84
check the picture change a Catcher or make the jumper ..post result
Old 12-05-2011, 10:01   #9 (permalink)
Member: 812018
Thanks Meter: 8
this is the right solution ......................................
Old 12-10-2011, 05:33   #10 (permalink)
Member: 1229689
Thanks Meter: 2
Old 12-12-2011, 15:54   #11 (permalink)
Member: 1342188
Sonork: 100.1607654
Thanks Meter: 129
check the picture change a catcher or make the jumper ..post result
it is working brother nice solution
Old 02-10-2014, 16:10   #12 (permalink)
Member: 1520671
Thanks Meter: 3
nokia 3500c no network when searching airtel, bsnl, tata are available. vodafone, aircel not available any solution
Old 02-10-2014, 16:25   #13 (permalink)
Member: 784847
Thanks Meter: 44
change pa ic all will be ok
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 12:35
Page generated in 0.33641 seconds with 9 queries
