Old 05-07-2007, 15:25   #1 (permalink)
Member: 317094
Thanks Meter: 2
network problems solution
Learn Here How To Service Network Problems
there is two sections in network 1, Rx section. 2, Tx section. all technicians need to use manual searching in mobile phone, testing for Rx section and Tx section.
HOW TO FIND WHICH SECTION IS FAULT Tx (or) Rx?
Testing Rx section
use manual search for Testing Rx section, after searching Rx section good condition means it shows network list like Airtel, hutch, (or) any other network list in your area,
If Rx section bad condition after searching it shows NO NETWORK FOUND
1, after searching it shows network list means Rx section is ok.
2, after searching it shows NO NETWORK FOUND means Rx section is fault.
Testing Tx section
Use manual search for testing Tx section, after searching it shows network list, then you can choose your simcard network, if Tx section is good condition it shows HOME NETWORK SELECTED, if Tx section is fault it shows NO ACCESS.
1, after selecting network it shows HOME NETWORK SELECTED means Tx section is ok.
2, after selected network it shows NO ACCESS means Tx section is fault.
Information of Rx section components and ics nokia dct-3 tech
1, antenna switch
2, RF IC ( Hagar ic )
3, AUDIO IC ( cobba ic)
4, crystal oscillator
5, filters
6, VCO (voltage control oscillator)
Information of Tx section components and ics nokia dct-3 tech
1, PF IC (PA IC)
Information of Rx section components and ics nokia dct-4 tech
1, antenna switch
2, filters
3, RF IC
5, VCO (voltage control oscillator)
6, UEM IC
Information of Tx section components and ics nokia dct-4 tech
1, PF IC (PA IC)
HOW TO SERVICE Rx SECTION FAULT ?
Solution for Rx section no network found fault nokia dct-3 technolagy
1,clean the pcb well and Rehot (if not ok follow one by one solutions)
1, give antenna switch jumper
2, Rehot the RF IC
3, Rehot the AUDIO IC
4, Reball the RF IC
5, change the RF IC
6, change the AUDIO IC
7, change the crystal oscillator
Solution for Rx section NO NETWORK FOUND fault nokia dct-4 technology
1, clean the pcb well and Rehot (if not ok follow one by one solutions)
2, give antenna switch jumper
3, Reheat the RF IC
4, change the crystal oscillator
5, Reball the RF IC
6, change the RF IC
7, Change filters
HOW TO SERVICE Tx SECTION FAULT ?
Solution for Tx section NO ACCESS fault nokia dct-3 technolagy
1, Change the PF IC
Solution for Tx section NO ACCESS fault nokia dct-4 technolagy
1, Change the PF IC
SOLUTION FOR OTHER NETWORK FUALT
Solution for low network coverage, all models
1, give jumper from antenna contact to cabinet antenna
2, change the antenna switch
Solution for dct-3 technology
When switch on the mobile it shows full network after few seconds its goas down
1, flash - Rebuild ime - UI settings (if not ok follow 2nd solution)
2, check the track from battery +ve point to PA IC, if track is ok then change the good PF IC.
Solution for dct-4 technology
1, write good pm file (if not ok follow 2nd solution)
2, change the PF IC, if still the problem same check the PF power track to battery +ve point
The Following User Says Thank You to enson uk For This Useful Post:
Nokia New Network Problem Solution ufuktakiadam Nokia Hardware & Hardware Repair 24 02-24-2010 10:29
Video 1110,1600,2310 network problem Solution ali_jaan Nokia Digital Core Technology 4 ( DCT-4 ) 0 05-11-2009 04:16
All New Nokia network problem solution asad_nomy7 Nokia Hardware & Hardware Repair 5 04-13-2009 14:25
c300 network problem solution satcomhedi Samsung Hardware Repair 1 07-24-2008 07:45
nokia network problem solution =GsMnL1-TeAm= Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-05-2002 23:46
Page generated in 0.18344 seconds with 9 queries
