12-26-2008, 13:08 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | new 3g i phone hang and only logo.try it 100% tested Guide: (UPDATED Nov 16th) (Look at step 6 first before doing anything) What files do I need? - Jailbreak Software (NEW VERSION) http://www.megaupload.com/?d=NM16TM73 QuickPWN 2.2 Jailbreak Download Mirror 2 http://www.badongo.com/file/12202173 QuickPWN 2.2 Jailbreak Download Mirror 3 http://rapidshare.com/files/16643524...PWN22.zip.html QuickPWN 2.2 Jailbreak Download Mirror 4 http://www.badongo.com/file/12202173 * iPhone firmware 2.2 download (246 MB) http://appldnld.apple.com.edgesuite....7_Restore.ipsw * iPhone 3G firmware 2.2 download (Caution if you upgrade to iPhone 3G http://appldnld.apple.com.edgesuite....7_Restore.ipsw 2.2 you won't be able to unlock your iPhone 3G) 1.1.2 Jailbreak (Updated) **** NOTE: This method currently requires you be on 1.1.1 of the firmware. If you are on 1.1.2 you must downgrade prior to being able to use this jailbreak. **** Updates: - Activation/YouTube for iPhones - Added an automatic fix for SpringBoard crash problem on touches - PPC support - Some improvements to crossplatform compatibili How to Put Your iPod into DFU Mode video http://www.youtube.com/watch?v=Rb_ss0bljHY How To Jailbreak A 2.0/2.0.1/2.0.2 iPod Touch / iPhone /iPhone 3G With WINPWN 2.5 video http://www.youtube.com/watch?v=1d6HJ...eature=related Step 1: Downgrade to 1.1.1 (if required) *** NOTE: This guide does not guarantee it will work 100%. Also errors 1015 is expected at the end of the process. Continue reading to understand. *** 1. Download the 1.1.1 ipsw firmware file from Apple. If the downloaded file has the extension ".zip", please remove it and modify it to end up with a filename ending in _Restore.ipsw 2. Reboot your iPhone holding the top (power) and home buttons BUT release the top button 10 seconds into it (right after the screen goes dark) and continue to hold the home button until iTunes detects the phone in recovery mode. The iPhone screen will appear to be off, but start iTunes if not started yet . 3. Restore your iPhone by pressing and holding the ‘Shift’ key on windows or ‘option’ key on Mac, then click ‘restore’ to select the 1.1.1 firmware file you downloaded earlier. The restore should go through and errors at the end with error 1015. However you will notice that the iphone is in DFU mode with the connect to itunes screen from 1.1.1. 4. In order to kick the phone out of that mode I just had to launch iNdependence version 1.2.5 and wait a minute or so. If you are using iTunes 7.5 you will have to get a MobileDevice from a previousv version in order to run Independence. - If iNdependence is not available or you are on a Windows machine, download a working copy of iPhuc and issue the following commands: cmd setenv auto-boot true cmd saveenv cmd fsboot ---------------------------------------------------------------------------------------------------- Step 2a: Jailbreak 1.1.1 on Unactivated iPhone *** NOTE: If your phone has been activated through iTunes, you can proceed to step 2b. *** 1. enter *#307# press call, now use the back button on the top of your screen to remove *#307# , now enter 0 , press call, press answer, press hold, press decline. And you get to the contact list. And thereafter every time you push the homebutton you just slide the "emergency call" slide, then enter 0 , press call, press hold, press decline. 2. Push contacts, end call and you get called again, this time hit decline and you access one of menus with favorites, you can edit contacts, do a test ride on keyboard, take photos etc. 3. Now edit a new contact and type in "prefs://11" as web-address and "http://jailbreakme.com" as an additional URL. 4. When you tap "prefs://11" you can now select your favorite WiFi gateway. 5. Now press the home button and move the slider to the dial-pad. 6. Now you can go back to the contact list by Dialing 0, push call, then answer, then contacts, then hit the "http://jailbreakme.com" web address you typed in. 7. Scroll down to the bottom, click "Install AppSnapp". Safari will exit and you'll return to your springboard. Wait for the phone to reboot. You are now jailbroken. and are able to use Installer.app. ---------------------------------------------------------------------------------------------------- Step 2b: Jailbreaking on iPod Touch or iTunes Activated iPhone 1. Launch Safari 2. Visit http://jailbreakme.com, Scroll down to the bottom, click "Install AppSnapp". Safari will exit and you'll return to your springboard. Slide to unlock, you are now jailbroken. and are able to use Installer.app. ---------------------------------------------------------------------------------------------------- Step 3: Prepare your 1.1.1 device for the Update 1. Launch Installer.app 2. Scroll down to Tweaks (1.1.1) 3. Select OktoPrep 4. Click Install ---------------------------------------------------------------------------------------------------- Step 3b: Prevent SpringBoard crash on previous hacked iPod touches If you have installed MobileMail on your iPod touch, there is a chance an update to 1.1.2 will render your device inoperable until a restore. This issue can be prevented by switching Auto-Check off. - Go to General->Mail->Auto-Check. Set it to Manual. If you forget to do this step and update, proceed with the jailbreak in step 5 (even though SpringBoard is unusable) and we will fix it for you. ---------------------------------------------------------------------------------------------------- Step 4: Update to 1.1.2 1. Connect your device to your computer 2. Launch iTunes 3. Choose your device 4. Click Update - If update still shows 1.1.1 as being the newest version, you may download the 1.1.2 from an Apple download server and shift-click (PC) or option-click (Mac) on "Check for update" and select the update you downloaded. - DO NOT CLICK OR SHIFT-CLICK RESTORE: That will wipe the changes OktoPrep made. 5. Wait forever for your device to update ---------------------------------------------------------------------------------------------------- Step 5: Jailbreak your iPod Touch or iPhone WARNING: If your iPhone is unactivated, it will be factory "hactivated" for you and YouTube enabled. If this is not desired behavior, activate your iPhone with iTunes before proceeding. 1. Close iTunes 2. Connect your device to your computer 3. On Windows, double click on windows.bat, on Mac, double click on jailbreak.jar 4. Follow the on screen instructions. ---------------------------------------------------------------------------------------------------- Step 6: Unlocking 1.1.2 Note: # This version of anySIM works only with 4.02.13_G baseband version and can be run on 1.0.2, or 1.1.1 jailbroken systems * The only way your baseband will be 4.02.13_G while you're running 1.0.2 or 1.1.1 is if you updated then downgraded firmware. 1) Start at 1.0.2 or 1.1.1 or 1.1.2, do a fresh 1.1.2 RESTORE This will load the new baseband firmware. 2) Now, RESTORE (downgrade) first to 1.1.1 and then to 1.0.2. This will not alter the baseband firmware, so it will still be the 1.1.2 version 3) Now on 1.0.2, jailbreak and install anySIM 1.2.1u 4) Run anySIM 1.2.1u to unlock the phone. Although you are running fw 1.0.2 with a 1.1.2 baseband, the phone will work. 5) Now RESTORE to 1.1.1 again 6) Do a jailbreakme.com and use installer to fetch and run OktoPrep 7) Now do an UPDATE (not restore) to 1.1.2. If you restore instead of updating then oktoprep is wiped out and you need to redo the steps. 8) Run the UPDATED jailbreak software. DO NOT RUN anySIM 1.2 under 1.1.2. It will not work properly and you risk corrupting your baseband. Enjoy! say thanks battooonnn |
01-28-2012, 09:47 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2011 Location: india
Member: 1694177 Status: Offline Sonork: 1619339 Thanks Meter: 23 | helo sir i phone 3g not connect to pc sir help me may i phone 3g not connect to pc ang hang on apple logo but charging is show help me sir help help me sir |
!!free fast and easy DEAD BB5 FLASHING,100% tested by me!! | jawad8305 | Nokia Base Band 5 ( BB-5 ) | 233 | 02-26-2012 10:38 |
You have new phone model and want to see it supported ? Read this... | alis | Infinity-Box | 2 | 02-03-2011 02:06 |
lg u8210 phone hang on startup logo | ahmertelecom | FuriousGold | 11 | 08-27-2009 18:06 |
You have new phone model and want to see it supported ? Read this... | InfinitySupport | Infinity-Box | 239 | 07-15-2009 19:26 |
Unlock and repair x65 v41 series 100% tested | thecult | S-Gold Based Phones | 191 | 02-17-2007 19:39 |
