New 8800 USB & charging connector ways 1 Attachment(s) 8800 Arte, Sapphire, Carbon and Gold |
Are you shure? Because the green line is ID.. wich in your picture goes to GND. |
R2007 must see mirrored left-right ! |
this not work every time. missing part in ID circuit |
can anybody know how work ID terminal on usb (battery?) Because I connect gnd and +5V (usb) and 8800 say: "charger not supported" Maybe we need resistor on ID (bellow bga chip)? |
1 Attachment(s) try this. this work. |
thank you for sharing.... |
u r welcome :) my solution Really works |
1 Attachment(s) Quote:
so, other case,,same model,Arte, first it was charger not supported,, then i make your solution and now dont come this message charger not supported but dont show about charging,,, when connect to PC all works,,PC suite,,soft update,,but dont charging,, i liik arrond btemp resistor and see,,somebody try to change this resistor and broke pcb contact pads,,, so ,questions is now,, where i can solder this 47K btemp resistor,because i dont found any point or contact or pad where is connection to BSI and Btemp at the same time,, please if you have any Idea,,... Best regards PS. look at picture,there is better explain |
R3401(btemp) near N2700 |
i haven't 8800 arte pcb for test. but try with microscope and scalp to find btemp wire. will be hard to make this but for now I not think other way. good luck. Quote:
but seems like you dont understand my case,, I know where is place R3401,this is very simple to find on shematics,, but on my Arte PCB there is broken solder pads on the place where R3401 was. so,my friend please look the picture and if you have any idea how to find this lower pads point please help.... |
i also have charging and usb conecting problem on a nokia 8800 arte. i changed the R2007 but nothing changed. any new ideas? |
nokia 8800 Quote:
