Old 12-20-2007, 10:59   #1 (permalink)
Member: 480959
Thanks Meter: 49
Cool 1100 Display Light
hello i have a Nokia 1100 its its display lite always on solution plz
The Following User Says Thank You to Sandeep_$tomar For This Useful Post:
Old 12-20-2007, 14:00   #2 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
Did u try another LCD?
Old 12-20-2007, 15:16   #3 (permalink)
noagsm's Avatar
Member: 606593
Thanks Meter: 68
or see water damage on bottom of keypad side elements
Old 12-20-2007, 15:30   #4 (permalink)
dil_PAKISTANI's Avatar
Member: 515273
Sonork: 100.1573940
Thanks Meter: 339
change its light ic problem will be solve
Old 12-20-2007, 17:28   #5 (permalink)
Member: 465901
Thanks Meter: 45
change the tree light ic and the diode your problem will be solved
Good Luck
Old 12-21-2007, 04:28   #6 (permalink)
Member: 56996
Thanks Meter: 9
history of the fone so that we can help you more...brother
br
Old 12-21-2007, 06:14   #7 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
first wash ur phone with acetone properly ........ if not solve then diplay ligt track and then change light ic......
Old 12-21-2007, 06:32   #8 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
rehot cpu wash and again bulb hit 30 munite u problem will be ok
Old 12-21-2007, 13:20   #9 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
three legged ic at the bottom might be faulty , try changing it
Old 12-21-2007, 15:50   #10 (permalink)
Member: 465901
Thanks Meter: 45
there is not three leged ic in 1100. in 1100 there is only one light ic which is six leged, change this ic and check the diode
Old 12-30-2007, 20:07   #11 (permalink)
Member: 480959
Thanks Meter: 49
Nothing Happend I had Tried All these things I also Flash It And Reboils ITs Flash But Same Problem Thanks For Ur Support
Old 12-31-2007, 04:16   #12 (permalink)
Member: 390195
Thanks Meter: 17
First u change LCD and then change light IC
Old 12-31-2007, 13:06   #13 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Smile 1100 display
replace this..........
The Following User Says Thank You to Vijendra Saini For This Useful Post:
Old 01-07-2008, 19:16   #14 (permalink)
Member: 460034
Thanks Meter: 30
Cool
Try This, Hope Your Problem Will Be Solved
The Following User Says Thank You to skybl For This Useful Post:
Old 01-09-2008, 20:46   #15 (permalink)
Member: 669218
Thanks Meter: 11
only change 2 parts step by step 1 diod 2 six legs ic. end chekc the lcd
Nokia 1100 display lights not power off astana2007 Nokia Digital Core Technology 4 ( DCT-4 ) 4 11-30-2008 20:02
1100 display light continuesly on sigamani Nokia Hardware & Hardware Repair 8 08-30-2008 18:35
1100 display light! khan6653 Nokia Hardware & Hardware Repair 0 08-07-2008 10:52
1100 display light always on gsmstyle_1 Nokia Hardware & Hardware Repair 5 07-21-2008 21:02
Nokia 1100 No Display Light haider Nokia Digital Core Technology 4 ( DCT-4 ) 7 07-02-2005 21:50
Page generated in 0.30525 seconds with 11 queries
