11-12-2006, 13:09 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 38
Member: 78440 Status: Offline Thanks Meter: 56 | nokia 3230 display problem |
The Following User Says Thank You to nomi For This Useful Post: |
11-12-2006, 13:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | first of all you shud chek call incoming and outgoing if ok then chang the display ic if call incoming and outgoing is not ok then problem is sofw |
11-23-2006, 10:05 | #4 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | i've change this display ic, ui board, lcd still same my lcd, ui board test on other 3230 still working how to solve??? this phone when i receive is light problem (lcd no light but still can see the words on lcd) after i make jumper (some trick find in forum) still no light at last i find the lcd connector in ui board broken 1 line, after connect it back light work fine but now display problem |
11-24-2006, 03:12 | #6 (permalink) | |
Member: 172261 Status: Offline Thanks Meter: 364 | Quote:
the ui board already changed do you mean these 3 part connector in main board | |
The Following 3 Users Say Thank You to andre128 For This Useful Post: |
11-29-2006, 10:30 | #12 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 364 | damn it....... today another 3230, i just remove housing clean the joystick, still no replace... suddenly no light... only can see picture/words i follow this http:///vbb/attach...4&d=1164334347 the main board become hot... no working... any solution??? |
nokia 3230 display problem | shammysaini | Nokia Hardware & Hardware Repair | 3 | 06-09-2009 07:44 |
nokia 3230 display blank | vimochan80 | Nokia Hardware & Hardware Repair | 3 | 11-30-2008 15:49 |
nokia 3230 displaying problem | de brain box | Nokia Hardware & Hardware Repair | 1 | 09-04-2008 20:18 |
Nokia 3230 Display Problem | stiffknot | Nokia Hardware & Hardware Repair | 7 | 06-21-2008 05:08 |
nokia 3230 display blinks every 5 6 seconds | raj_cxe | WD2 & APE (Symbian Phones) | 13 | 02-16-2007 19:05 |
