Old 11-21-2004, 07:07   #1 (permalink)
Member: 38922
Thanks Meter: 35
NOKIA 83/6510 "INSERT SIM CARD" <<New FinaL SOLUTION<<
Hi Mates, everybody know how diffucult its working without Microscope (also with is not perfekt). Also everybody know the famous INSERT SIM CARD problem. But till' here we have been bridged with wire the Points for this Repair Trick (like an wire circle) Now i found a new way to make this work much easier and repairing faster! We dont need the 2 Black Pads, ok we can destroy it in caution..(keep out please) till the pads are not on the PCB, so it can't be a short circuit if we connect the gray Pads together like in the Picture i prepared.
P.S This means also if you want, then you must not use a wire to brigde it...everybody how he want..this part is your choose.
GreetZ @ ALL
Old 11-21-2004, 07:18   #2 (permalink)
genocite's Avatar
Member: 5379
nice and new vision about destroying the unused point, never think of it be4
good thinking mate
Old 11-21-2004, 11:42   #3 (permalink)
Member: 51793
Thanks Meter: 31
Thanks man for the explainations. A great help indeed.
Old 11-21-2004, 12:45   #4 (permalink)
sumeda's Avatar
Member: 71960
Thanks Meter: 5
thanks cyberoptik for your new method.
it will save time i'm sure.
BR..
Old 11-21-2004, 13:16   #5 (permalink)
Rolf2's Avatar
Member: 34145
Thanks Meter: 16
you can easily use few ohms smd resistors as bridge - no need to destroy any pads ...
R.
Old 11-21-2004, 14:37   #6 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
can we used this solution for keypad filter problem in 3650 or ngage ?
they are used almost same filter, only we have to find In and Out path
Old 11-21-2004, 16:24   #7 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
@CyberoptiK
nice like all ways
good work br
*****************Azam****************
Old 11-22-2004, 01:06   #8 (permalink)
Member: 38922
Thanks Meter: 35
R.
Its true, also this, but often is the problem that people wont search Resistors, have not spare parts etc. if people want save money and repair it self etc.. you know?
Also you can use the old solution. Its your choose..
Therefore i must look the SM, have ya already done? I think there r other trackways..
GreetZ
Old 11-25-2004, 03:08   #9 (permalink)
Member: 38922
Thanks Meter: 35
>Now i have been tryed also for 3650, it works.
GreetZ
Old 12-24-2004, 00:16   #10 (permalink)
Member: 6358
Thanks Meter: 10
@CyberoptiK, can you post the connections in 3650 keypad filter?
Best regards
Old 03-07-2005, 12:10   #11 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
Originally Posted by CyberoptiK
we connect the gray Pads together ike in the Picture i prepared
Where is the picture???
Can you atach again???
And it is not gonna work for 7210 because it is diferent...so distory the pads is bad solution
Regards
Old 03-07-2005, 19:18   #12 (permalink)
Member: 38922
Thanks Meter: 35
here again uploaded in server:
GreetZ
Old 03-08-2005, 02:14   #13 (permalink)
Member: 72946
Thanks Meter: 2
Regards
i dont think so, this very good Solution, for working and repair without microscope and make it eays fast. Respect!
Old 03-08-2005, 11:20   #14 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
8310-6510-6500 sim waysss
open exposition
net to draw
The Following User Says Thank You to sevgigsm For This Useful Post:
Old 06-23-2007, 18:20   #15 (permalink)
Member: 237492
Originally Posted by sevgigsm View Post
open exposition
net to draw
NOT WORKING!!!!!!!!!!!!!
nokia 2310 "contact service" in n battery, "insert sim card" in sowtfare smarttech Nokia Digital Core Technology 4 ( DCT-4 ) 15 08-12-2010 08:16
NOKIA 3100 "Insert Sim Card" umr_khan Nokia Hardware & Hardware Repair 10 07-02-2006 06:28
in a nokia 6320,suddenly showing "insert sim card" pls help shinojmahe Nokia Hardware & Hardware Repair 0 06-01-2006 07:18
NOKIA 3100 "Insert Sim Card" umr_khan Nokia Hardware & Hardware Repair 5 03-20-2006 16:45
nokia 1100 "insert sim card" after dropped waater eng.hamdow Nokia Hardware & Hardware Repair 4 11-21-2005 16:01
Page generated in 0.23705 seconds with 10 queries
