05-01-2011, 06:51 | #1 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1435780 Status: Offline Thanks Meter: 1 | n2626 hung Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...Processing MCU file: rm291__06.81.mcusw [DCT4,DCT4 ALGORITHM] size: 8.60 MB Supported Ids: 3040 ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...flashing terminated ! RX Buffer: 01000000009172 |
05-01-2011, 13:14 | #3 (permalink) |
Freak Poster Join Date: Jan 2007 Location: PATIALA
Member: 440801 Status: Offline Sonork: 100.1604292 Thanks Meter: 44 | Just flash with ufs with good F-bus cable. If set will not done after flash.It means this is hardware problem...Rehot flash ic or reball.....lastly reball UEM.....good luck |
K700 hung / freeze hardware solution | Platijet | Sony Ericsson Hardware Repair | 134 | 06-26-2010 08:38 |
x430 hung up | didinagma | Trident/AGERE Platform | 1 | 12-05-2005 22:02 |
C350 hungs in call | naahou2000 | Motorola P2k | 0 | 12-26-2004 21:34 |
3310, @ 1st hunging than Contact Service | autko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 12-20-2004 15:22 |
Mars fls with Hung lang | Blueman1 | Mitsubishi | 0 | 10-02-2002 23:25 |
