06-18-2008, 11:33 | #1 (permalink) |
Junior Member Join Date: Dec 2007 Location: Indonesian
Member: 649509 Status: Offline Thanks Meter: 2 | Ngage >>>>>help 2nd Boot: w2_2nd.fia, Ver: 4.70.1 Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,0001257E,Amd 29BDS643GT Algorithm: s2_amd_b.fia, Ver: 4.70.1 Algorithm Ok, MSID: 84AFBCD99514A015D9BEDB1959 Decoded MSID: 3E4EBAF7-000DB1D9-A8000000 Encoded FAID: 3CCDA2D0-9A876BD4-E808F7DE IMAGE: nem440.3c1 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x006FFFFF Erased, Time: 01:20 Area3: 0x02000000-0x023FFFFF Erased, Time: 00:47 Area4: 0x04000000-0x046B4FFF Erased, Time: 01:19 BT MCM (26) Image Found: 22, 0x0002DD94 BT MCM Flashing Done, Time: 00:13 Write Error: DATA 14 Chk, at: 0x003F2000 Process Failed, Repowering Mobile |
06-19-2008, 17:18 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Firstly try to erased full flash then write the flash file if problem is were seemed again try to flash with JAF. Thankz. Xtreme Mobile. BRB. |
06-19-2008, 17:27 | #4 (permalink) |
Freak Poster Join Date: May 2008 Location: Uganda
Member: 774126 Status: Offline Sonork: 100.1645006 Thanks Meter: 42 | first try to flash only mcu and ppm with the same device, if still the same then change device. if no change still, try to reheat flash ic BUT only if you are sure you can do it, otherwise you could damage your phone if care is not taken. |
>>>>>help your brother<<<<< | helin | UST Pro II | 3 | 09-17-2008 14:38 |
>>>>>help abute log<<<<<<<< | helin | Cruiser Suite | 1 | 07-06-2008 19:33 |
May i play ngage games on ngage area without ngage? | m00dy | Nokia Multimedia | 1 | 07-01-2006 13:46 |
