05-07-2007, 13:14 | #1 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Johor
Member: 318664 Status: Offline Thanks Meter: 6 | nk 1600 need help |
05-07-2007, 14:08 | #3 (permalink) |
Junior Member Join Date: Apr 2007
Member: 498483 Status: Offline Thanks Meter: 0 | Software Hi Dera hope u fine read urs problem very simple you should Flash nokia_1600 on jaf box problem will b solve or change language file i mean ppm=IA format enjoy urself ASAD |
05-07-2007, 14:17 | #4 (permalink) |
Member: 498483 Status: Offline Thanks Meter: 0 | Software HI read ur problem change ppm file mean language file vid the format IA or flash it on jaf box it will Be work correctly inshahllah. sending u image of 1600 but its 100 percent software problem ok take care bye |
05-10-2007, 15:11 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | Erase then full flash with latest flash file and write pm file.use the same version v3.42 but latest one.Other file even though its v.3.42 have problem,and when you use them to reflash ends up into sim card not valid and then contact service. |
05-11-2007, 20:08 | #9 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: india
Member: 239231 Status: Offline Sonork: 100.1615723 Thanks Meter: 110 | Quote:
if u r getting insert sim check wether the IMEI is not corupted or remove tht r2205 resistance n then check or flash it with latest version.... REGARDS | |
1600 need help | skd_123 | Nokia Hardware & Hardware Repair | 2 | 12-23-2008 08:22 |
NK 1600 with imei ????? | mdpm | Universalbox | 1 | 11-22-2007 08:39 |
NK-1600 contact service | zakir375 | Nokia Hardware & Hardware Repair | 1 | 09-20-2007 08:02 |
Nk 1600 900/1800 to 850/1900 | nost | Nokia Hardware & Hardware Repair | 0 | 08-21-2007 23:38 |
1600 need help | skd_123 | Nokia Hardware & Hardware Repair | 3 | 08-21-2006 16:16 |
