nk 6085 blue display sir, today i received a nokia 6085 in the fault of blue display but incoming & out going was ok just i changed 3 wire connector (patta) but no result just i flashed with with 4.30 , 5.03 , 6.00 but now set is dead flashing is successfull with u.b the hand set just on for 2-3 secondssss with blue display after just shut off again tell me any solution, thanx in advance (ashish mobile & communication) |
sir also have problem with flashing with jaf when i just connect jaf box and i go in bb5 section after selection of 6085 jaf select files automaticaly and i click on flash button i and getting message bye jaf (manual mode selected version cannot be checked ) flashing failed |
chenge flex cable all ok |
yes i changed the glass ic's close to the connector click on the board oday and all was ok |
nokia 6085 if blue display but incoming & outgoing ok, first chang flex cable if same problem change both glass ic from n70 , or,6630, 6680, 3230, 6260, it was 100% solution. |
dear why u flash ? its 100% hrdwere problem ,ok forget it, try to mobile return previous condition that mean incoming & outgoing condition than just change two lcd ic.good luck. |
I have aslo same problem on my nokia 6085 and i already change flex cable and crystal ic now small display is ok but main display is blue screen still .How can I solve it . Please help me. |
just change lcd board 1000000% ok.i solved this problem many 6085 |
you dnt need to flashed the set you would have ask forum b4 you do so,you should flash it again n change flex if not change display ic |
chenge flex cable........ |
