Old 06-25-2008, 19:38   #1 (permalink)
Member: 645970
Thanks Meter: 157
Thumbs up nk 6085 blue display
sir, today i received a nokia 6085 in the fault of blue display but incoming & out going was ok just i changed 3 wire connector (patta) but no result just i flashed with with 4.30 , 5.03 , 6.00 but now set is dead flashing is successfull with u.b the hand set just on for 2-3 secondssss with blue display after just shut off again tell me any solution, thanx in advance (ashish mobile & communication)
The Following User Says Thank You to ashish mobile For This Useful Post:
Old 06-25-2008, 19:43   #2 (permalink)
Member: 645970
Thanks Meter: 157
sir also have problem with flashing with jaf when i just connect jaf box and i go in bb5 section after selection of 6085 jaf select files automaticaly and i click on flash button i and getting message bye jaf (manual mode selected version cannot be checked ) flashing failed
Old 06-25-2008, 19:45   #3 (permalink)
Member: 64012
chenge flex cable all ok
The Following User Says Thank You to vantech For This Useful Post:
Old 06-25-2008, 20:05   #4 (permalink)
Member: 461923
Thanks Meter: 2,015
..blue lcd on nokia 6085 is hardwere problem..change flex and lcd..if not work change both lcd IC driver...
Old 06-25-2008, 21:38   #5 (permalink)
Member: 197720
Thanks Meter: 24
yes i changed the glass ic's close to the connector click on the board oday and all was ok
Old 06-27-2008, 19:48   #6 (permalink)
Member: 761248
Sonork: masumkb
Thanks Meter: 28
nokia 6085 if blue display but incoming & outgoing ok, first chang flex cable if same problem change both glass ic from n70 , or,6630, 6680, 3230, 6260, it was 100% solution.
Old 09-08-2008, 20:31   #7 (permalink)
Member: 761248
Sonork: masumkb
Thanks Meter: 28
dear why u flash ? its 100% hrdwere problem ,ok forget it, try to mobile return previous condition that mean incoming & outgoing condition than just change two lcd ic.good luck.
Old 09-10-2010, 12:49   #8 (permalink)
Member: 729536
Thanks Meter: 13
I have aslo same problem on my nokia 6085 and i already change flex cable and crystal ic now small display is ok but main display is blue screen still .How can I solve it . Please help me.
Old 09-10-2010, 12:55   #9 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 759
just change lcd board 1000000% ok.i solved this problem many 6085
Old 09-10-2010, 13:02   #10 (permalink)
Member: 729536
Thanks Meter: 13
I changed LCD board but problem is still same
The Following User Says Thank You to Gautam Mhz For This Useful Post:
Old 09-10-2010, 13:25   #11 (permalink)
Member: 601591
Thanks Meter: 84
you dnt need to flashed the set you would have ask forum
b4 you do so,you should flash it again n change flex if not change display ic
Old 09-10-2010, 13:31   #12 (permalink)
papu3090's Avatar
Member: 852566
Thanks Meter: 459
chenge flex cable........
Old 09-10-2010, 13:33   #13 (permalink)
papu3090's Avatar
Member: 852566
Thanks Meter: 459
The Following 4 Users Say Thank You to papu3090 For This Useful Post:
6085 blue display? jawad8305 Nokia Hardware & Hardware Repair 20 07-13-2011 11:20
6085 blue display smsismail Nokia Hardware & Hardware Repair 4 11-16-2009 06:00
6085 Blue Display , Please Try To Help Me,,,,,,,,,,,,,,,,,,,,, munnachikku Nokia Base Band 5 ( BB-5 ) 3 06-01-2008 13:57
6085 blue display rock01112 Nokia Hardware & Hardware Repair 3 04-19-2008 12:58
6085 blue display vishal123123 Nokia Hardware & Hardware Repair 5 04-12-2008 20:58
Page generated in 0.37138 seconds with 8 queries
