01-30-2009, 18:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | no body can solve 6230i prob...i bet any body can help me to solve this problam....i,ll very thanxfull |
01-30-2009, 22:46 | #7 (permalink) |
Major Poster Join Date: Nov 2008
Member: 905846 Status: Offline Thanks Meter: 26 | Try to switch to other system. Meaning that if you in GSM(900MHz), try testing DCS(1800MHz) or PCS (1900MHz). And then test it. If you don’t have Agilent test equipment try to search network providers (manual search). Then….. If you realize that one of PCS/DCS/GSM doesn't work (while others do) that means that the problem is defiantly in your antenna SW (or disconnection in that area of PCB) that commands the network switching. If you find out that you can find all the providers (manual search), but still have a problem in the network (full reception after manual search but still can't make a call) then your RF circuit is fine, but the problem is the power supply, so try to reheat the D400 and look if that helps (nokia always have a problem with Upp). Good luck. |
01-31-2009, 22:15 | #9 (permalink) |
Member: 719944 Status: Offline Thanks Meter: 2,117 | thanx all of u experts .........but i think there is no easy salution for that......nobody want to change uem and other sensitive parts due to time shortage ........if any body have any good and 100000% salution for this then it,ll BIG job for all members....thnx again any way all of u and waiting for good salution. Last edited by chohansahib; 01-31-2009 at 22:21. |
5200 problem any body can solve thanks in advance | sanjayvikas | Nokia Base Band 5 ( BB-5 ) | 9 | 03-19-2010 08:40 |
Any body can solve my problem with 5310? | imran78669 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-02-2010 10:46 |
any body can solve this prob....plzzz ? | chohansahib | Sony Ericsson Hardware Repair | 6 | 01-25-2010 06:50 |
is there sumone who can solve my prob | .:KHALIFA:. | Nokia Base Band 5 ( BB-5 ) | 1 | 10-19-2006 00:01 |
