Old 08-21-2010, 08:10   #1 (permalink)
Member: 1173626
Thanks Meter: 59
no Graff only set on nokia 1200
set is on by pressing on off swich but dose not off only set is show disply and key pad light
report given info by ufs please tell me solution
MCU SW : V 5.80 14-11-08 RH-99 (c) NMP
PPM SW : V 5.80 14-11-08 RH-99 (c) NMP EJ
Prd.Code: 0546370
Bpr.Code: 0544418
Prod.Sn : ILA522868
HW Vers : 2500
UEM : 1328
UPP : 8850 [2292]
RFIC Ver: 0700
DSP Vers: ICPR62_08w31_UPP
LCD Type: UNKWN: IDs: 00:ff:00
IMEI : 358962-01-616350-2
SL Conf : 001-01-00000000000
SL Prof : 800000000001000-B
SL Var : 00003589620161635000
SL Aux : 000B0000
HW Sig : 536CE9BE804660E4
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Old 08-21-2010, 15:40   #2 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
Prd.Code: 0546370
Bpr.Code: 0544418
Prod.Sn : ILA522868
HW Vers : 2500
UEM : 1328
good
UPP : 8850 [2292]
RFIC Ver: 0700
SL Aux : 000B0000
change lcd ur problem solved .
Old 08-22-2010, 22:22   #3 (permalink)
Registered User
Member: 1087294
Thanks Meter: 252
first change lcd and ribin both if not solved finally change lcd connector on board many time solved by me use it and post reply
Page generated in 0.14066 seconds with 9 queries
