Old 09-27-2006, 08:52   #1 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
Thumbs up No Need To Put New Keypad Ic
NOW HERE IS THE EASY AND WITHOUT NE EXPENCE
SOLUTION JUST GO THROUGH THE IMAGE
AND ENJOY
POST UR REPLY
CHECKED ON NOKIA 6070
AS I HAVE PROBLEM IN MY 6070
http:///vbb/showthread.php?t=335573
Old 09-27-2006, 09:41   #2 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 98
AND ENJOY
POST UR REPLY
Where is the image in u r link??
Old 09-28-2006, 16:35   #3 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
u having ringer solution in ngage qd
can u having solution for no ringtone in ngage qd pls help me or give direct jumper for ringer
Old 09-29-2006, 06:34   #4 (permalink)
smr29126's Avatar
Member: 189855
Thanks Meter: 31
any one test it or not??
i will test it and post results i think this is not too easy it has ping pong connections not so simple.
Old 09-29-2006, 16:43   #5 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
AND ENJOY
POST UR REPLY
i think something wrong in this pic.
be care full abt make jumpre as this pic. http://forum.gsmhosting.com/vbb/atta...6&d=1159446012
check here keypad ic data and it in/out pin.no.
Old 02-13-2007, 11:34   #6 (permalink)
Member: 158975
Thanks Meter: 17
anyone try this? post results
Old 02-13-2007, 11:44   #7 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
This is Great if this really works, Most of us is running out of Keypad IC.
Old 02-13-2007, 12:30   #8 (permalink)
Member: 158975
Thanks Meter: 17
anyone test this scheme? pls answere if the results are positives...10q
Old 02-13-2007, 13:22   #9 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
if this tips really working out????kndly post ur results here..bcoz,jst i tried wth this in one phone..it fails...may b,i wrkd in a hurry,i need time to check it out...anyone,kndly post ur result here..
waitng..
Old 02-13-2007, 13:29   #10 (permalink)
Member: 432364
Thanks Meter: 270
Thank you i will tri this.
B.r.
Sunil.
Old 02-17-2007, 17:44   #11 (permalink)
kindo's Avatar
Member: 300886
Thanks Meter: 61
becarefull !!!!
here is the right solution
Old 02-17-2007, 19:51   #12 (permalink)
Member: 73601
Thanks Meter: 3
this solution will never work. Dont wast the time.
Old 02-17-2007, 20:10   #13 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 408
poor solution.... will never wrk.....
kindo's solution is right....
Old 02-17-2007, 20:33   #14 (permalink)
Member: 234532
Thanks Meter: 25
It is not easy to connect pins each other,ofcourse it is not impossible but not eassy. use only when ic not available.it is more easy to replace ic whith new one.
Old 02-17-2007, 22:54   #15 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
thank you for this solution
New Keypad Ic Jumper For 6120,6300,N76.... Jeffyoh88 Nokia Hardware & Hardware Repair 6 10-31-2012 08:14
5610 new keypad ic jumpers or compatible ??????? smartengghelp Nokia Hardware & Hardware Repair 8 07-29-2008 08:54
Uid Bb5 Box Now Coming With Jigs ( No Need To Solder No Need Take Out Flash Ic ) shadi Main Sales Section 0 09-19-2007 17:56
for all`UID BB5 Unlock BOX NOW MORE EASY * NO NEED TO ENTER CODE VIA KEYPAD * armany99 Nokia Base Band 5 ( BB-5 ) 62 08-08-2007 08:08
U`ID BB5 Unlock BOX NOW MORE EASY * NO NEED TO ENTER CODE VIA KEYPAD * hafiz Main Sales Section 0 08-07-2007 10:14
Page generated in 0.24678 seconds with 10 queries
