06-22-2006, 14:49 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 210449 Status: Offline Thanks Meter: 2 | noia 1100.not charging.fuse and diode are oky.but.. well nokia 1100,not cahrging. i checked. fuse and diodes are oky. suply also comming. what will be the problem?? can any one guide me pls??? thanks in advance wt lov |
06-23-2006, 15:06 | #6 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 247683 Status: Offline Thanks Meter: 49 | Quote:
first check your uem output voltage man good luck | |
06-24-2006, 01:32 | #10 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Be Age: 48
Member: 3081 Status: Offline Thanks Meter: 8 | My ***!!! There are so many posts about this problem, why don't u use search function of this forum? Is working perfect. In 70% of tese phones with charging problem is UEM that has to be changed.Change that R100, is a varistor and u should use one from same value. if this doesn't solve the problem just change that UEM with a blank one write a rpl and that's it. If after this the phone goes off after 30 just flash the phone. |
06-24-2006, 07:13 | #13 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 73797 Status: Offline Thanks Meter: 19 | Quote:
however u want to unlock or lock k750i. use kzf application(use cable with external power supply) | |
06-24-2006, 07:15 | #14 (permalink) | |
06-24-2006, 12:32 | #15 (permalink) | |
Member: 3081 Status: Offline Thanks Meter: 8 | Quote:
1100 not charging and auto charging | gsmsikar | Nokia Hardware & Hardware Repair | 11 | 03-23-2009 23:30 |
1100 not charging solution? | etcelfon | Nokia Hardware & Hardware Repair | 4 | 07-30-2008 16:20 |
1100 not charging and dead | kprajeesh4u | Nokia Hardware & Hardware Repair | 20 | 06-19-2007 17:23 |
E365 not charging fuse change and nothing | wgmmmx | Motorola Hardware Repair | 1 | 02-23-2006 17:33 |
1100 not charging | jaaja | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 03-07-2005 04:55 |
