08-28-2005, 18:11 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Age: 45
Member: 43545 Status: Offline Thanks Meter: 7 | nok.7610 menu problem i have one nok.7610 all keys are working but only one menu key is not working i chane bot 2 cry ic i already check key pad connector ....after that still same ....is there any one have any idea plllllllllllll.........tahnks Tanmay india |
03-06-2006, 14:28 | #2 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 46
Member: 19094 Status: Offline Thanks Meter: 3 | Quote:
I have tried the top board with keypad and lcd from another fully working handset but its still the same,,,the phone is not water damaged also Any ideas guys?? TIA | |
The Following User Says Thank You to agent003 For This Useful Post: |
03-15-2006, 18:13 | #5 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | clean the phone.try with another new ic... if not working then change upper keypad Last edited by ..::ArchitRaj::..; 03-13-2007 at 18:52. |
The Following User Says Thank You to ..::ArchitRaj::.. For This Useful Post: |
08-12-2007, 14:02 | #7 (permalink) |
Freak Poster Join Date: Nov 2005 Location: PAKISTAN
Member: 203615 Status: Offline Thanks Meter: 55 | hi friends 7610 left right and up down key not working 1 i changed the 2ic but not 2 changed the uperkey pad it still not working plz help with thanks zahid |
08-12-2007, 20:42 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | By puneet1484 at 2007-08-11 |
09-02-2007, 12:41 | #10 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | i got simillar kind of problem. 6670 up & down keys not working changed key pad, same result. changed left key ic , problem solved but only for few hourse, then same resolved, same rechanged key ic, again same result(work for few hours) br |
Nokia 7610 Menu Key Problem | saurabh_bhola | Nokia Hardware & Hardware Repair | 10 | 10-06-2013 13:43 |
nok 7610 auto power on | bashir_icon | Nokia Hardware & Hardware Repair | 2 | 09-20-2008 16:39 |
nok. 7610 | azim35 | Nokia Hardware & Hardware Repair | 0 | 08-03-2008 19:02 |
nok 7610 | azim35 | Nokia Hardware & Hardware Repair | 3 | 07-08-2008 14:44 |
7610 contacts menu problem with startup failed | PERSIA-GSM | Nokia Hardware & Hardware Repair | 12 | 03-02-2006 21:57 |
