Old 01-13-2012, 06:21   #1 (permalink)
Member: 1490943
Thanks Meter: 7
noka 5130 uisetting failed
nokia 5130x flashing completed bt no power on and uisetting failed...how to slove
Old 01-13-2012, 06:57   #2 (permalink)
papu3090's Avatar
Member: 852566
Thanks Meter: 464
cpu het normal.....and flashing
Old 01-13-2012, 08:42   #3 (permalink)
jaan G's Avatar
Member: 1438545
Sonork: 100.1610062
Thanks Meter: 49
bro flash with latest ver..... if not solve then clean cpu and give het normal......and flash again
Old 01-30-2012, 18:48   #4 (permalink)
pintu.pattnaik1's Avatar
Member: 1351981
Sonork: 100.1640597
Thanks Meter: 48
nokia 5130x flashing completed and uisetting failed plzzzzzzz help me
Old 01-30-2012, 20:16   #5 (permalink)
Member: 1509319
Thanks Meter: 16
its just because of the software u flashed with, simply re flash the phone using the latest version that is with 7.97 your problem will be solved hundred percentage
Old 01-31-2012, 04:28   #6 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
yes flash with latest version
remove camera Then check
for better post logs....
Old 02-03-2012, 22:37   #7 (permalink)
Member: 694751
Sonork: confido
Thanks Meter: 7
I had similar problem, but in my own case, the IMEI is now 12345610654321? any body with solution? lps help
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
5130 V.61 bzegarac Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-20-2000 11:37
5130 5190 6190 MGG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-03-2000 20:36
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.22169 seconds with 10 queries
