07-03-2008, 15:43 | #3 (permalink) |
Freak Poster Join Date: Jul 2008 Location: P A K I S T A N
Member: 805902 Status: Offline Thanks Meter: 31 | give little heat on its rams care fully n then flash it its tested solution checked by me |
The Following User Says Thank You to cellsolutions1 For This Useful Post: |
07-19-2008, 19:41 | #4 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Sialkot Age: 39
Member: 578828 Status: Offline Thanks Meter: 88 | nokia has 2 dirctories of signal 1-TX(that mean trasmiter) 2-RX(that mean receiver) 3-when i understand that is rx and tx problem??? 3/1The most problems of TX are(when you power on the phone, signal is well but..before the light is off, signal shut down 3/2 The most problems of RX are (when you switch on the phone and you have not signal I DONT KNOW IF YOU UNDERSTAND THE DIFERENCE OF 2 CAUSES? ANYWAY THESE ARE IN GENERAL 4- Whitch parts of nokia are RX and TX? 4/1- PA (power amplificator)is only TX(trasmiter) 4/2- DUBLEXER is RX and TX too PA AND DUBLEXER EXEPT THE SIGNAL THEY CAUSE MOST OF PROBLEMS WHEN NOKIA SHUT DAWN WHEN MAKE A CALL 4/3 HAGAR -is RX and have a little part of TX but 80% of received signal is hagar 4/4 COBBA is TX and a little RX but cobba cause most of contact service in nokia and when you listen bad in earphone 4/5 32.768 KHZ REAL TIME CLOCK cause too much problems of signal and when the phone shut dawn inormaly you must listen the ring of the phone if it is too slowly 32.768khz must be change 4/6 CCONTI TRASMIT ELECTRICITY ALL NOKIA PARTS most of problems when the phone not swhitch on the problem is cconti 4/7 FLASH IC cause most of contact service in nokia and signal ( when you switch on the phone and you have not signal but only the name operator example ( like only vodafone but nothink signal) is a flash problem OK MAN I WISH U UNDERSTAND ME PLEASE RATE THESE THREAD (BECAUSE ALL CAN SEE IT) |
The Following 2 Users Say Thank You to gsmawan For This Useful Post: |
09-01-2008, 17:31 | #5 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Good Explanation dear. But this is not answer of his question. Anyway @ Nadeem Amin Did u try to flash the phone..... If YES then post here flashing Log. Post result. | |
nokia 6600 dead taking flashing,but still dead | sandeepmtc | Nokia Hardware & Hardware Repair | 0 | 08-24-2007 17:53 |
6600 flashing error now 6600 dead | kabeermaster25 | Nokia Hardware & Hardware Repair | 25 | 04-08-2006 02:31 |
6600 dead.......... | zdob | Griffin | 16 | 11-08-2004 09:38 |
6600 dead after flashing with new 4.09.1 | mohd_anan | WD2 & APE (Symbian Phones) | 7 | 04-26-2004 06:55 |
6600 Dead | marukiaro | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 02-24-2004 00:26 |
