Old 01-28-2011, 09:42   #1 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Thumbs up Noki X5 Solution- USB Not charging problem issues
Here's the solution that may help fix or repair Nokia X5 USB charging problem. When the device shows no charging indication when the battery charger is plug-in, the components showed on the solution below such as the chip fuse and a diode might possibly damaged.This solution shows the location of the components that needs to check or then replace if found damaged.
Repair hints:
Check the USB pin connector and ensure that it is free from dirt or oxidation, clean or replace it if necessary.
Check the chip fuse if open, replace if damaged
Check the diode if shorted, replaced if damaged
If the fuse and the diode is okay but the charging problem still exists proceed to rework or replace the USB charger voltage controller IC, it is located at the rear side of the PCB board.
Old 09-26-2012, 08:06   #2 (permalink)
Member: 730812
Sonork: +6281365931440
Thanks Meter: 60
thank's a lot bro...
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.13825 seconds with 10 queries
