Old 10-14-2013, 11:45   #1 (permalink)
800800's Avatar
Member: 433942
Thanks Meter: 34
Nokia 100 Contact Service
Nokia 100 Contact Service..
I Flash With Letest Flash File 4.40
But No Result..
CPU Type: XG110 2.1B
History : I recived for Insert Sim so i jumper & OK but
After i again show insert sim so now i open the phone & Rejumper but after phone not switch on.. & Only Contact Service....
Plz Give Me solution plz....
thanks in advanced....
The Following 2 Users Say Thank You to 800800 For This Useful Post:
Old 10-14-2013, 11:48   #2 (permalink)
800800's Avatar
Member: 433942
Thanks Meter: 34
I Have Atf
15:53:33 : Basic Phone Information
15:53:33 : ================================================
15:53:33 : MCU Version: V 04.40 19-10-12 RH-130 (c) Nokia
15:53:33 : IMEI Plain : 359286041031396
15:53:33 : IMEI Spare : A359286041031390
15:53:33 : IMEI SV : 33592860410313933F
15:53:33 : Phone Type : RH-130
15:53:33 :
15:53:33 : Extended Phone Information
15:53:33 : Product Serial Number: EC2A7CAAI
15:53:33 : Product Code : 059J2D3
15:53:33 : Module Code : 0204875
15:53:33 : Basic Production Code: 059F6X3
15:53:34 : PPM SW Version : V 04.10 06-08-12 RH-130 (c) Nokia IB
15:53:34 : ADSP Version : p+V 03.25\n16-09-11\nRH-130\n(c) NMP\nmg_nlt
15:53:34 : MCU SW Version : V 04.40 19-10-12 RH-130 (c) Nokia
15:53:34 : HW Version : 3051
15:53:34 : UEM Version : 1328
15:53:34 : UPP Version : 8850
15:53:34 : LCD Version : UNKWN: IDs: 00:00:00
15:53:35 :
15:53:35 : ================================================
15:53:35 : Simlock Information
15:53:36 : CONFIG KEY : 8181000807000000
15:53:36 : PROVIDER KEY : 0040000005FFFFFF
15:53:36 : NETWORK NAME : Unknown Provider
15:53:36 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
15:53:36 : SIMLOCK TABLE :
15:53:36 : SIMLOCK STATE : Not Locked
15:53:36 :
15:53:36 : SIMLOCK_TYPE : PA_SL1
15:53:36 : SIMLOCK_TEST : PASSED
15:53:36 : SECURITY_TEST : PASSED
15:53:37 : PHONE_MODE : LOCAL
Old 10-14-2013, 12:02   #3 (permalink)
abbaas's Avatar
Member: 1237819
Thanks Meter: 141
bro onlay in one solution cheek this remove l c d & print i m tested 1000%
abbas
The Following 2 Users Say Thank You to abbaas For This Useful Post:
Old 10-14-2013, 12:18   #4 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 98
i think you should check lcd ways or change lcd because of this :15:53:34 : LCD Version : UNKWN: IDs: 00:00:00
The Following 2 Users Say Thank You to jamohaki For This Useful Post:
Old 10-14-2013, 13:41   #5 (permalink)
N.C.Erepola's Avatar
Member: 1615710
Sonork: 100.1647890
Thanks Meter: 200
This kind of faults comes because Static electricity. Electronic components inside mobile phones are very sensitive to Static electricity. Always try to use a
Antistatic wrist strap
when you repair.
The Following 3 Users Say Thank You to N.C.Erepola For This Useful Post:
Old 10-14-2013, 14:43   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,217
yes
jamohaki is right
The Following User Says Thank You to HUM For This Useful Post:
Old 10-15-2013, 04:12   #7 (permalink)
munnabhi's Avatar
Member: 1299626
Sonork: 100.1625198
Thanks Meter: 61
plz chang lcd bro ,...........................
The Following User Says Thank You to munnabhi For This Useful Post:
Old 10-15-2013, 19:25   #8 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,122
@800800 ,
what is d status of ur set ? seems it's water damage .
post reply
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 10-15-2013, 19:50   #9 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,085
Check lcd tracks if not ok then jumper it if ok then change lcd it will be okkk
tested by me many times.......
B/R
HITECH INDIA
The Following User Says Thank You to hitech care For This Useful Post:
Old 10-16-2013, 05:45   #10 (permalink)
800800's Avatar
Member: 433942
Thanks Meter: 34
I change Lcd . .
But Self Test Show : LCD Version : UNKWN: IDs: 00:00:00
The Following User Says Thank You to 800800 For This Useful Post:
Old 10-16-2013, 07:05   #11 (permalink)
Member: 1051906
Sonork: 44448
Thanks Meter: 130
I change Lcd . .
bro you check display track your probalm is solved.its yor help
Uploaded with ImageShack.us
The Following User Says Thank You to thamizh For This Useful Post:
Old 10-16-2013, 09:15   #12 (permalink)
800800's Avatar
Member: 433942
Thanks Meter: 34
Now My Problem is Solve by lcd tracking..
After i switch on the phone but then "Restart On Nokia Logo "
SO I Flashing.. but mcu file upload sucssesfully upload but cnt & ppm file not upload ...
12:02:39 : Basic Phone Information
12:02:39 : ================================================
12:02:39 : MCU Version: V 03.70 08-12-11 RH-130 (c) Nokia
12:02:39 : IMEI Plain : 359286041031396
12:02:39 : IMEI Spare : A359286041031390
12:02:39 : IMEI SV : 33592860410313923F
12:02:39 : Phone Type : RH-130
12:02:39 :
12:02:39 : Extended Phone Information
12:02:39 : Product Serial Number: EC2A7CAAI
12:02:39 : Product Code : 059J2D3
12:02:39 : Module Code : 0204875
12:02:39 : Basic Production Code: 059F6X3
12:02:40 : PPM SW Version : V 04.10 06-08-12 RH-130 (c) Nokia IB
12:02:40 : ADSP Version : p+V 03.25\n16-09-11\nRH-130\n(c) NMP\nmg_nlt
12:02:40 : MCU SW Version : V 03.70 08-12-11 RH-130 (c) Nokia
12:02:40 : HW Version : 3051
12:02:40 : UEM Version : 1328
12:02:40 : UPP Version : 8850
12:02:40 : LCD Version : WIN:BOHAIv93 NT39121
12:02:41 :
12:02:41 : ================================================
12:02:41 : Simlock Information
12:02:42 : CONFIG KEY : 8181000807000000
12:02:42 : PROVIDER KEY : 0040000005FFFFFF
12:02:42 : NETWORK NAME : Unknown Provider
12:02:42 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
12:02:42 : SIMLOCK TABLE :
12:02:42 : SIMLOCK STATE : Not Locked
12:02:42 :
12:02:42 : SIMLOCK_TYPE : PA_SL1
12:02:42 : SIMLOCK_TEST : PASSED
12:02:42 : SECURITY_TEST : PASSED
12:02:42 : PHONE_MODE : LOCAL
12:03:33 : TIME STARTS HERE
12:03:33 : ************************************************** ****
12:03:33 :
12:03:33 :
12:03:33 : Sending PBL 19456 bytes...
12:03:33 : PBL Successfully Sent...
12:03:33 :
12:03:33 : Sending SBL 65024 bytes...
12:03:34 : SBL Successfully Sent...
12:03:34 :
12:03:34 : Flash Chip Manufacturer: Samsung Electronics Corp.
12:03:34 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
12:03:34 : Extended Information: Multiple Bank / Burst / 1.8v
12:03:34 :
12:03:34 : Processing Image File: C:\Documents and Settings\Administrator\Desktop\RH 130\EC6874D1_rh130_003.70ad
12:03:34 :
12:03:34 : FIRMWARE Image Found...
12:03:34 : Number of Sections: 01
12:03:34 : FIRMWARE Certificate Block Sent Successfully...
12:03:34 : Processing Section 01 of 01
12:03:34 : FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
12:03:34 : ERROR: Erase FIRMWARE Block Failed !!!
12:03:34 : Flashing ERROR
How to Solve it now...
b,coz i difrrent type of use flash file but same problem..
plz help me....
Old 10-16-2013, 09:16   #13 (permalink)
Member: 2002598
pls give me download link to the latest flasher tnx..
The Following User Says Thank You to bonch22 For This Useful Post:
Old 02-06-2014, 10:49   #14 (permalink)
Member: 2121940
Sonork: 100.1597028
Thanks Meter: 5
brother mu nokia 100 contact service problum i chaing lcd & try flashing plzzzzz solution..........................................
The Following User Says Thank You to bashabhaicumbum For This Useful Post:
Old 02-06-2014, 14:22   #15 (permalink)
samithashiva's Avatar
Member: 1356665
Sonork: 123
Thanks Meter: 29
use mx box then cs recover..................
The Following User Says Thank You to samithashiva For This Useful Post:
Page generated in 0.40969 seconds with 7 queries
