Old 03-03-2013, 16:27   #1 (permalink)
Crazy Poster
Member: 1605843
Thanks Meter: 7
Nokia 100 xgold flash without a LCD???
Is it possible to flash Nokia 100 ( xgold platform) without a LCD display ?
I have hard that Infineon Xgod patform base cpu s do not power on the phone when it detects there is no LCD connected or when there is broken LDC connected.
MX Box dose not detect the phone. LCD display is totally broken.
I want to know can I flash this kind of phones which has damaged LCD s????
Old 03-03-2013, 17:20   #2 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
can be flashed but no power on.
The Following User Says Thank You to baldev For This Useful Post:
Old 03-03-2013, 17:35   #3 (permalink)
samithashiva's Avatar
Member: 1356665
Sonork: 123
Thanks Meter: 31
u doesnt flash change only lcd ur problem is solved 100% its tested solution by me
The Following User Says Thank You to samithashiva For This Useful Post:
Old 03-03-2013, 18:09   #4 (permalink)
Crazy Poster
Member: 1605843
Thanks Meter: 7
Dear,
What I want to know is whether i can flash this phone before i replacing the LCD
Because this LCD has been fully cracked by drop. Therefore I want to check wether the phone is still good before I buy a new LCD.
That is why I want it to flash before i buy a LCD.
I think it can be flash without having a LCD even it would not power on untill i replace the CD
But Mx Box dose not detect the phone so I guess that not only the LCD which has been broken but also the mother board
Old 03-05-2013, 08:36   #5 (permalink)
Member: 1767975
Thanks Meter: 27
first check with power supply if phone getting volt and needle moving than check all lcd ways and change lcd but if no volt on supply check board rehot cup and check
Old 03-05-2013, 08:37   #6 (permalink)
Member: 1767975
Thanks Meter: 27
u can flash any nokia xgold cpu other etc.. without lcd no problem
Old 03-06-2013, 16:53   #7 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 154
Dear,
about mx box i do'nt know but in atf box you can flash this set without lcd
and about to buy a lcd it is very cheep and it should be spare in numbers
Old 03-06-2013, 17:33   #8 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
You can read info and flash xgold chip in mx-key hti without lcd!
Tried and tested!!
Sent from my n7100 using Tapatalk
The Following User Says Thank You to Sniper_04 For This Useful Post:
Old 03-07-2013, 04:26   #9 (permalink)
Member: 1895501
Sonork: 36830
Old 03-10-2013, 11:26   #10 (permalink)
Crazy Poster
Member: 1605843
Thanks Meter: 7
I could flashed it without a LCD
The problem was in the Fbus cable i thot that was a phone which dosent have a LCD.
Thanks all
Page generated in 0.20861 seconds with 8 queries
